It is currently Mon Jun 22, 2026 1:38 pm
PostPosted: Mon Feb 08, 2010 3:29 am
the 2 lines from the carb to the charcoal cannister and the one line from the fuel tank...........can i plug off these lines and eliminate the cannister to "clean-up" the engine compartment?.........no emmisions after35 years here in nc.
PostPosted: Mon Feb 08, 2010 6:08 am
That would be an unhelpful thing to do. The canister works for you, not against you. If you plug it off your fuel tank won't be properly or safely vented. See this post.
 Post subject: Charcoal canister lines
PostPosted: Mon Feb 08, 2010 12:04 pm
I agree, it is very nice to have it hooked up and working. The car smells so much better with it.....especially during heat soak on hot days.
Click on the red link below my name for pictures on routing the lines. I tried to clean it up the best I could......
 Post subject: thanks
PostPosted: Mon Feb 08, 2010 5:12 pm
Thanks Dan and Ted.......very interesting article from Dan and fabulous pics from Ted.....if you dont mind i will use some of your ideas on my build.[url][/url]
