E-body and A-body a904 trans- same dimensions? easy swap?
https://slantsix.org/forum/viewtopic.php?t=38949
Page 1 of 1
Author:  radarsonwheels [ Tue Feb 09, 2010 11:34 am ]
Post subject:  E-body and A-body a904 trans- same dimensions? easy swap?
Quick question- the title says it all!
Thanks
Author:  Doc [ Tue Feb 09, 2010 11:43 am ]
Yes, the 904 "family" of transmissions all have the same basic case and rear cross-member mounting location.
There are a lot of changes related to the year of the transmission, the biggest one was the change in 1966, going away from the cable linkage / rear flange set-up and to the mechancal / slip-in yoke version.
There is also the input shaft / converter change in 1968.
Simple answer, a 70 A-body 904 trans will bolt right into a 70 E-body, if already equipped with a 904.
Author:  radarsonwheels [ Tue Feb 09, 2010 2:23 pm ]
Post subject:  Thanks Doc!
