| Vac pot list? https://slantsix.org/forum/viewtopic.php?t=38952 |
| Author: | hellion_locdogg [ Tue Feb 09, 2010 3:52 pm ] |
| Post subject: | Vac pot list? |
Where can I find the vac pot list. I know it exists and I already looked through the FAQ's. Thanks ,Cliff |
| Author: | Aggressive Ted [ Tue Feb 09, 2010 4:04 pm ] |
The recuve sticky is where Dan's and Ceej's list should be......or you could do a search......or PM me with your email and I can send you a copy later when I get home. |
| Author: | SlantSixDan [ Tue Feb 09, 2010 6:31 pm ] |
The post you're after is here and probably ought to be in a sticky. |
| Author: | ceej [ Tue Feb 09, 2010 6:37 pm ] |
It can be found in the Electrical FAQ. I'll link it into the engine FAQ! Still working the bugs out! CJ |
| Author: | hellion_locdogg [ Tue Feb 09, 2010 7:06 pm ] |
Thanks Dan, knew it was here somewhere. ,Cliff |
| Author: | hellion_locdogg [ Tue Feb 09, 2010 7:42 pm ] |
So the vc-208 seems like the pot to have. The only ones I can find have an arm that bends right instead of left. Anyone find a vc-208 for a points dist.? |
| Author: | hellion_locdogg [ Fri Feb 12, 2010 1:09 am ] |
BUMP |
| Author: | SlantSixDan [ Fri Feb 12, 2010 7:36 am ] |
There's nothing such as a "VC-208 for a points distributor". You can use the VC-208 if you use a '72 breaker plate, but why go through the hassle for a cruddy system like points? Put in an electronic distributor. |
| Author: | 66aCUDA [ Sun Feb 14, 2010 7:11 am ] |
Or better yet HEI. Frank |
| Author: | SlantSixDan [ Sun Feb 14, 2010 7:40 am ] |
HEI requires an electronic distributor. |
