| Erson's Cam Lash https://slantsix.org/forum/viewtopic.php?t=38953 |
| Author: | Dan-o [ Tue Feb 09, 2010 6:30 pm ] |
| Post subject: | Erson's Cam Lash |
I lost my card, anyone know what the lash is supposed to be for the ersons cams? I did a search and everything from .12 to .22 came up. I believe that my cam was in the .460-.470 lift range. |
| Author: | dakight [ Tue Feb 09, 2010 7:24 pm ] |
My cam is the Erson 270 with .465 lift. The recommended lash is .015 int. / .015 ex. for this cam. |
| Author: | Dan-o [ Tue Feb 09, 2010 8:03 pm ] |
sounds like a good place to start, thanks. |
| Author: | 66aCUDA [ Wed Feb 10, 2010 6:58 am ] |
If you get the number off the end of the cam I should be able to get the lash for you. My "special" is .022 I/E so they vary. Frank |
| Author: | kesteb [ Fri Feb 12, 2010 7:09 pm ] |
The Erson cam card says .023 I/E hot for that cam. |
| Author: | Dan-o [ Fri Feb 12, 2010 10:30 pm ] |
All right, its set at .015 for now, I'll be firing it up this weekend, after break in, I'll see how she sounds, if need be I'll back it down. |
| Author: | 66aCUDA [ Sun Feb 14, 2010 7:03 am ] |
.008 is a lot I would back them off. Seeing as you have the correct number of .023. Just my 02. Frank |
| Author: | dakight [ Sun Feb 14, 2010 9:01 am ] |
I'm not sure how it was determined that .023 was the correct lash. I don't see where the cam was positively identified. All we have that I can see is that it is an Erson with lift in the range of .460-.470. My Erson 270 has a lift of .465 and the card for it specifies a running clearance of .015 intake and exhaust. What am I missing? |
| Author: | 66aCUDA [ Mon Feb 15, 2010 7:14 am ] |
Sorry I thought we had IDed it. Still better loose by .008 than tight by .008. Frank |
| Author: | Doctor Dodge [ Mon Feb 15, 2010 9:04 am ] |
Having used a number of the Erson grinds, I would start off at .018 lash on the intakes and .020 on the exhaust. If it starts and runs smooth at idle without ticking, I would double-check the lash hot and try going a touch looser on the exhaust (.022)and a touch tighter (.016) on the intake, just to see if you like it better. Just my 2 cents... DD |
| Author: | kesteb [ Thu Feb 18, 2010 12:31 pm ] |
Quote: I'm not sure how it was determined that .023 was the correct lash. I don't see where the cam was positively identified. All we have that I can see is that it is an Erson with lift in the range of .460-.470. My Erson 270 has a lift of .465 and the card for it specifies a running clearance of .015 intake and exhaust. What am I missing?
Erson #E 470621 - TQ 20 Mduration 270 lift .465 center line 107 The cam card says .023 hot for intake and exhaust. When I set up may engine, I did .020 cold I/E for initial startup. It ran fine but the vacuum gauge was bouncing around. It is now set at .022 hot I/E, with no valve train clatter. Vacumm gauge is now between 13 and 14 at 750 rpm, with a noticeable lope to the idle. |
| Author: | dakight [ Thu Feb 18, 2010 4:33 pm ] |
Quote: Quote: I'm not sure how it was determined that .023 was the correct lash. I don't see where the cam was positively identified. All we have that I can see is that it is an Erson with lift in the range of .460-.470. My Erson 270 has a lift of .465 and the card for it specifies a running clearance of .015 intake and exhaust. What am I missing?
| Author: | kesteb [ Mon Feb 22, 2010 10:34 pm ] |
My card is the similar, but with a different format. The only difference is the lash setting. Mine is .023 hot and yours is presumably .015 cold, .008 for heat build up in the valve train seems reasonable. |
| Author: | dakight [ Tue Feb 23, 2010 3:33 am ] |
I should probably call them before I install it, just to clarify. I don't see anything to indicate whether the setting is hot or cold. The other thing I see is that you said your cam is 107* centerline but mine is indicated at 111* but the grind number is the same. I wonder why the difference.... |
