| Time for a rebuild, need cam advise https://slantsix.org/forum/viewtopic.php?t=38958 |
Page 1 of 2 |
| Author: | raPoM [ Wed Feb 10, 2010 10:51 am ] |
| Post subject: | Time for a rebuild, need cam advise |
Just threw a rod throught the block on my way back from Vegas. Need to do a rebuild on the quicks.Need cam advise,here is what I have: 1967 Dart 225 904(with low first and lockup) Daily driver Going to do a complete rebuild .030 over Big Valve Head with mild port work about 9.0-1 comp Super six iron intake with holley 350 carb Long tube headers with 2 1/2 exhaust. 8 3/4 rear with 3.23's Want max performance with above combo,and stock stall/LU convertor. |
| Author: | Joshie225 [ Wed Feb 10, 2010 11:06 am ] |
With a stock torque converter I'd use the Erson RV-15 that Doc designed. See this thread for more info. http://slantsix.org/forum/viewtopic.php ... son#227653 You could stand quite a bit more duration and make more power if you were willing to buy a high stall converter. Everything else in your combo supports more cam duration. |
| Author: | Doc [ Wed Feb 10, 2010 11:44 am ] |
How do you like idle quality? How high do you want to rev the engine? What is the RPM you like to drive at on the open road? DD |
| Author: | Shaker223 [ Wed Feb 10, 2010 12:39 pm ] |
Remember, if you're thinking of going turbo, you might want a larger LSA and a little different on the duration. |
| Author: | raPoM [ Wed Feb 10, 2010 2:40 pm ] |
Turbo is a furture goal,but I might just buy a different cam for the later down the road. I like a lumpy idle,as long as its not horrible at a stop light in D. I would like it to rev to 5500-6000 3.23's with 26" tall tires should put me anywhere from 2500+ rpm I would imagine. |
| Author: | raPoM [ Wed Feb 10, 2010 2:46 pm ] |
Quote: With a stock torque converter I'd use the Erson RV-15 that Doc designed. See this thread for more info. http://slantsix.org/forum/viewtopic.php ... son#227653
I am more than willing to buy a high stall convertor.Its price that is holding me back. I only have enough for the machine work and rebuild kit.Will be doing all other work myself...
| Author: | Doc [ Wed Feb 10, 2010 5:06 pm ] |
Some nice Erson SL6 "street cam" options: Erson 244 MP "clone" cam in a RDP design is called RV10M-212/.295 The next step up, also an RDP cam has been named RV15M-212/.295 Here is the cam sheet on the last one I ordered and used. I would NOT grind 4 degrees of advance into the RDP RV15M-212/.295 as shown on the sheet. ( I had to retard the cam 4 degrees when I installed it to get the events in a good place) DD http://www.dutra.org/pictures/engine/er ... am60bd.jpg |
| Author: | 66aCUDA [ Thu Feb 11, 2010 6:23 am ] |
I have a different idea on the cam. I really like the Erson 280/270 and you do have the engine work to support it. Either way a New TC would help alot. Even if you used a stock cam. My02. Frank |
| Author: | raPoM [ Thu Feb 11, 2010 10:39 am ] |
I plan on buying a convertor,but it wont be for a few months down the road. Would it be ok to run something like the 280/270 with no convertor,untill I can buy one? Or will it really be a dog? |
| Author: | 66aCUDA [ Thu Feb 11, 2010 5:00 pm ] |
I ran the 280/270 for 3 months without a high stall, it ran fine just worse on gas milage. I was not trying to race so it wasnt a big deal. Frank |
| Author: | 1974duster kev [ Thu Feb 11, 2010 7:46 pm ] |
I guess i wont really be a big help since i was running a 3000rpm converter with my 270 erson cam but i liked it, it wouold launch hard and pull over 5000rpm depending on the timing |
| Author: | Dart270 [ Fri Feb 12, 2010 4:48 am ] |
It *might* be OK with 9:1 comp minimum and a good ign timing tuneup. Also, degree it at 100 centerline (yes, you read that right). Lou |
| Author: | Romeo Furio [ Fri Feb 12, 2010 6:00 am ] |
| Post subject: | blown up |
Hey, What the heck happened ?? When you were leaving on Sat I thought , man that thing has a nice rumble to it. Loose oil??? |
| Author: | raPoM [ Fri Feb 12, 2010 10:10 am ] |
Must have lost oil,the oil pressure was unhooked |
| Author: | raPoM [ Fri Feb 12, 2010 10:17 am ] |
Ordered! Got the 280/270 will deg. in at 100 as lou says! |
| Page 1 of 2 | All times are UTC-08:00 |
