It is currently Sat Aug 15, 2026 12:22 pm
PostPosted: Tue Dec 21, 2010 11:05 pm
I noticed that the Super Six intake has a largish protrusion from the EGR system below the intake ports. Should this be ground down? I intend to block the EGR and fill in the passage so that the floor of the intake was level... Is removing the bulge in the floor a good idea, bad idea?
PostPosted: Wed Dec 22, 2010 12:38 am
The bump matters very little for flow. I've drilled, tapped and plugged this passage, but on the outside where it's easier to do.
Users browsing this forum: Bing [Bot] and 18 guests
