droning sound
https://slantsix.org/forum/viewtopic.php?t=38977
Author:  Angry Squirrels [ Thu Feb 11, 2010 11:54 pm ]
Post subject:  droning sound
Don't really know where to put this, but here it goes, I noticed when my car is at speed ( say 55mph and above) i get this droning sound, sounds like a "WUMPH WUMPH WUMPH WUMPH" from the rear of the car. I know it needs tires, could this be the issue? I was thinking driveshaft out of balance perhaps?
Author:  66aCUDA [ Fri Feb 12, 2010 6:05 am ]
Fix the tire problem First. Then see(hear) if there is still a problem.
Frank
Author:  Louise76 [ Fri Feb 12, 2010 11:24 am ]
Maybe swapping all wheels front to rear, see if the sound follows? Pat
Author:  Doc [ Fri Feb 12, 2010 12:07 pm ]
If the vehicle has a 7 1/4 rear axle, it is likely that the axle bearing(s) need replacement.
Author:  Angry Squirrels [ Fri Feb 12, 2010 9:05 pm ]
Tires were of no help, but how would I find out if I have the 71/4 axle?
Author:  ESP47 [ Sat Feb 13, 2010 9:51 am ]
Check out this picture
http://www.moparmailinglist.com/content ... ed/381.jpg
You most likely have a 7 1/4. If it looks confusing under the car, just count out the bolts on the rear cover. A 7 1/4 should have 9. You'll need to identify which side the noise is coming from and pull that axle. Take it down to a machine shop to have a new bearing pressed on. Then go get yourself a seal from an auto parts store. Remove the old seal, install the new seal and then put the axle back in and connect everything back up.
Author:  hellion_locdogg [ Sat Feb 13, 2010 1:16 pm ]
Been through this for the last two years! It's the driveline... If you have a ball and trunion set up it is that for sure. If not just have it balanced($30) and change the trani mout while you're at it.
http://www.slantsix.org/forum/viewtopic.php?t=38191
,Cliff
