Crankshaft Welding (off topic)
https://slantsix.org/forum/viewtopic.php?t=3901
Page 1 of 1
Author:  Matt Wilson [ Fri Jul 12, 2002 8:54 pm ]
Post subject:  Crankshaft Welding (off topic)
Hey guys,
I have to apologize for being off-topic, but it looks like you all may know more about this topic than some of the other folks I usually deal with. I have some questions about crankshaft welding. I have a '49 Dodge pickup with a 230 cid flathead 6. I recently had the rear main seal surface welded, to get rid of rust pitting and build up the slightly undersized diameter.
The rear main seal surface is just a bit larger diameter than the main bearing journal diameters. The seal surface is just in front of the flywheel flange, but not part of the flange.
Anyway, my machinist removed about 0.030" from the surface, then proceeded to weld it with a "tri-gas" setup. After he finished welding it and grinding it, the region where the seal touches the shaft looked fine, but the adjacent material had some pits left over. I don't believe these were the typical weld pits, but rather I think they were remnants of the "valleys" between the weld beads. I didn't want to ask him to re-weld and re-grind, because he had already welded up the surface once before, but had ground it down too much and had to do it all again, so I was wary of over-welding. I decided to polish out a few of these "pits" and found a couple of them to be about 0.040" deep. I'm concerned that these irregularities can be stress risers, where fatigue cracks can start. What do you all think?
The other issue is that my machinist did not pre-heat or post-heat the crankshaft. Will the metallurgy be adversely affected because of this?
My crankshaft is a forged steel unit. The only thing I know about its composition is what I found in an old manual, which says it's "high-carbon" steel. I plan to make a few performance mods to the engine (dual carb intake manifold, headers, cam, high-compression head).
The welding process he uses is a "tri-gas" setup. What can you guys tell me about this?
I'm sorry for the long post, but just wondering if my crankshaft will come apart on me someday.
Thanks for your info!
Matt
mattengr@aol.com
Author:  bud L. [ Sat Jul 13, 2002 12:13 am ]
Post subject:  Re: Crankshaft Welding (off topic)
: Hey guys,
: I have to apologize for being off-topic, but it
: looks like you all may know more about this
: topic than some of the other folks I usually
: deal with. I have some questions about
: crankshaft welding. I have a '49 Dodge
: pickup with a 230 cid flathead 6. I recently
: had the rear main seal surface welded, to
: get rid of rust pitting and build up the
: slightly undersized diameter.
: The rear main seal surface is just a bit larger
: diameter than the main bearing journal
: diameters. The seal surface is just in front
: of the flywheel flange, but not part of the
: flange.
: Anyway, my machinist removed about 0.030"
: from the surface, then proceeded to weld it
: with a "tri-gas" setup. After he
: finished welding it and grinding it, the
: region where the seal touches the shaft
: looked fine, but the adjacent material had
: some pits left over. I don't believe these
: were the typical weld pits, but rather I
: think they were remnants of the
: "valleys" between the weld beads.
: I didn't want to ask him to re-weld and
: re-grind, because he had already welded up
: the surface once before, but had ground it
: down too much and had to do it all again, so
: I was wary of over-welding. I decided to
: polish out a few of these "pits"
: and found a couple of them to be about
: 0.040" deep. I'm concerned that these
: irregularities can be stress risers, where
: fatigue cracks can start. What do you all
: think?
: The other issue is that my machinist did not
: pre-heat or post-heat the crankshaft. Will
: the metallurgy be adversely affected because
: of this?
: My crankshaft is a forged steel unit. The only
: thing I know about its composition is what I
: found in an old manual, which says it's
: "high-carbon" steel. I plan to
: make a few performance mods to the engine
: (dual carb intake manifold, headers, cam,
: high-compression head).
: The welding process he uses is a
: "tri-gas" setup. What can you guys
: tell me about this?
: I'm sorry for the long post, but just wondering
: if my crankshaft will come apart on me
: someday.
: Thanks for your info!
: Matt
First, I don't know anything about this 'tri-gas' setup. Perhaps it is something relatively new.
Up until about 15 years ago, I was a journeyman machinist. I worked in a marine machine shop, and one of the things we did was weld stainless 'liners' on forged steel propeller shafts, up to 2' in dia. and 48' long. We used a shaft lathe and a machine to feed flux-filled stainless wire. It is important to maintain the proper angle of the welding head to achieve proper overlap of the beads of weld. It is also critical to maintain a constant correct tangential speed of the surface of the workpiece, and the feed of the lathe apron that holds the fixture. You also have to thoroughly remove the slag from the previous bead before you lay another bead against it. Otherwise you'll encapsulate the slag in the weld, which causes all kinds of problems(some of which you guessed). Occasionally, we would have minor 'inclusions', which we would expose during the machining process. When we approached finish size(say, +.040" to +.060"), we would dye penetrant check the o/s journal. If any pits were 'developed', we would die grind the inclusion out until the hole was gone and then fill in the hole with solid weld. And repeat until it was right.
Yes, preheating is a good idea.
Air cooling should be slow and done by slowly turning the crank in the machine lathe.
Yes, the inclusions can adversely affect the crank.
If you had problems with rust(that you can see) on the surface before, you can have more problems with rust(that you can't see) in the new pits.
Will any of these things cause you problems down the road? Who knows? How will it be used? It doesn't sound like an ideal job, but it might be OK.
Just curious, why didn't you have it sprayed-up, or even chromed?
fglmopar@aol.com
Author:  Doctor Dodge (Doug Dutra) [ Sat Jul 13, 2002 1:41 am ]
: First, I don't know anything about this
: 'tri-gas' setup. Perhaps it is something
: relatively new.
: . . . Occasionally, we would have
: minor 'inclusions', which we would expose
: during the machining process. When we
: approached finish size(say, +.040" to
: +.060"), we would dye penetrant check
: the o/s journal. If any pits were
: 'developed', we would die grind the
: inclusion out until the hole was gone and
: then fill in the hole with solid weld. And
: repeat until it was right.
: Yes, preheating is a good idea.
: Air cooling should be slow and done by slowly
: turning the crank in the machine lathe.
: Yes, the inclusions can adversely affect the
: crank.
: Will any of these things cause you problems
: down the road? Who knows? How will it be
: used? It doesn't sound like an ideal job,
: but it might be OK.
Sounds a lot like welding-up and off-set grinding a stroker crank. The preferred welder used here is a "submerged arc" wire feed machine. As the name indicates, the welding is electric and done in a coolant to prevent heat and slag build-up.
As for your "tri-gas" weld job, does the surrounding area show signs of excess heat build-up (discoloration)? Does the crank still "ring like a bell" if you tap the welded flange end with a hammer? (Just a small tap, don't get crazy.)
If you want, have the crank re-heat treated or nitride surfaced hardened but be warned, it will bend and grow (or shrink) depending on the metal alloy and heat treatment process.
As Bud points-out, these "weld-ups" take special equipment, knowledge and time, touch-up of exposed pits and imperfections is the major "hassle" with the welds. Remember that these surface imperfections are just that, surface problems. Yes, with enough time and stress these can be the starting points for cracks but how much time & stress? (who knows)
My view, try it and see what happens, worse case is that rear flange will snap off the crank. (Is this an automatic or a manual trans with a big flywheel / clutch?? I may think twice if there is a big flywheel spinning on that flange.)
For what it's worth, I have done 3 "submerged arc" weld & regrind stroker SL6 cranks and every one of them has had some minor welding pits in the journal surfaces. None of these cranks have failed on me yet. (One has been in service for 9 years.)
Author:  Matt Wilson [ Sun Jul 14, 2002 1:09 pm ]
: relatively new.
: Up until about 15 years ago, I was a journeyman
: machinist. I worked in a marine machine
: shop, and one of the things we did was weld
: stainless 'liners' on forged steel propeller
: shafts, up to 2' in dia. and 48' long. We
: used a shaft lathe and a machine to feed
: flux-filled stainless wire. It is important
: to maintain the proper angle of the welding
: head to achieve proper overlap of the beads
: of weld. It is also critical to maintain a
: constant correct tangential speed of the
: surface of the workpiece, and the feed of
: the lathe apron that holds the fixture. You
: also have to thoroughly remove the slag from
: the previous bead before you lay another
: bead against it. Otherwise you'll
: encapsulate the slag in the weld, which
: causes all kinds of problems(some of which
: you guessed). Occasionally, we would have
: crank.
: If you had problems with rust(that you can see)
: on the surface before, you can have more
: problems with rust(that you can't see) in
: the new pits.
: Just curious, why didn't you have it
: sprayed-up, or even chromed?
Hey Bud,
Thanks for the response! The tri-gas setup that this guy has appears to be pretty antiquated. I think it's quite a bit older technology than the modern submerged arc welding processes. However, it has automatic indexing of the weld head, with pre-set rotational speed, and the weld material is automatic feed, like a mig welder.
As I said, my machinist did not pre-heat, but he did let it air cool while rotating, as you mentioned.
As for chroming or spray-welding, I think that is probably the way I should have gone, in retrospect. I was concerned that either process might have begun to flake off with time, though. Also, I did not know if the surface could be sprayed up enough to build up the diameter sufficiently after machining down to remove the rust pits.
I'm in the process of putting this thing back together, and I think it will be ok, but I just thought I'd ask.
Thanks!
Matt
mattengr@aol.com
Author:  Matt Wilson [ Sun Jul 14, 2002 1:21 pm ]
: Sounds a lot like welding-up and off-set
: grinding a stroker crank. The preferred
: welder used here is a "submerged
: arc" wire feed machined. As the name
: indicates, the welding is electric and done
: in a coolent to prevent heat and slag
: build-up.
: As for your "tri-gas" weld job, does
: the surrounding area show signs of excess
: heat build-up? (discoloration) Does the
: crank still "ring like a bell" if
: you tap the welded flange end with a hammer?
: (just a small tap, don't get crazy)
: If you want, have the crank re-heat treated or
: nitride surfaced hardened but be warned, it
: will bend and grow (or shrink) depending on
: the metal alloy and heat treatment process.
: As Bud points-out, these "weld-ups"
: take special equipment, knowledge and time,
: touch-up of exposed pits and imperfections
: is the major "hassel" with the
: welds. Remember that these surface
: imperfections are just that, surface
: problems. Yes with enough time and stress
: these can be the starting points for cracks
: but how much time & stress? (who knows)
: My view, try it and see what happens, worse
: case is that rear flange will snap-off the
: crank. (is this an automatic or a manual
: trans with a big flywheel / clutch?? I may
: think twice if there is a big flywheel
: spinning on that flange)
: For what it's worth, I have done 3
: "submerged arc" weld & regrind
: stroker SL6 cranks and every one of them has
: had some minor welding pits in the journal
: surfaces. None of these cranks have failed
: on me yet. (one has been in service for 9
: years)
: DD
Hey Doug, thanks for the input!
I don't have the crankshaft right here in front of me at the moment, as I am out of town. However, I don't recall seeing that the surrounding material looked discolored at all. I'll try the "ring" test when I get back home.
Yes, there is a big, heavy flywheel on the back, but considering that the weight of the flywheel is pretty small compared to the forces acting on the main journals, and considering that this "journal" where the seal rides is a bigger diameter than the mains, I think the flywheel will be pretty insignificant. Also, this part of the crankshaft only sees torque, but no bending, like the main journals would see, so I think the stresses are pretty darn low.
It is good to know that even the stroker cranks you've built had some left over pits, and they haven't broken yet.
As you suggested, I am going to use this crank, but I wanted to get a bit more reassurance, as I would not want to get stranded out in the boonies somewhere. My truck is a '49 Power Wagon, so I'll be doing some amount of off-roading with it, but nothing real hard on the engine.
A couple of more questions: On your stroker cranks, did your machinist/welder pre-heat or post-heat, and are your crankshafts forged or cast?
Thanks again! Dodge people are always helpful.
Matt
mattengr@aol.com
Author:  Doctor Dodge (Doug Dutra) [ Sun Jul 14, 2002 5:43 pm ]
: It is good to know that even the stroker cranks
: you've built had some left over pits, and
: they haven't broken yet.
: As you suggested, I am going to use this crank,
: but I wanted to get a bit more reassurance,
: as I would not want to get stranded out in
: the boonies somewhere. My truck is a '49
: Power Wagon, so I'll be doing some amount of
: off-roading with it, but nothing real hard
: on the engine.
: A couple of more questions: On your stroker
: cranks, did your machinist/welder pre-heat
: or post-heat, and are your crankshafts
: forged or cast?
: Thanks again! Dodge people are always helpful.
: Matt
The weld & regrind cranks I have done are forged steel units, all were done with a submerged arc machine, none were pre-heated but all were cooled in the machine fluid for a while after all the welding. (because it's to hot to handle)
The last one I did was nitride hardened afterwards, that crank now has a real hard skin.
