| Modified Oil Pan for 60 - 66 A-Body https://slantsix.org/forum/viewtopic.php?t=39040 |
| Author: | Rick Covalt [ Thu Feb 18, 2010 4:41 pm ] |
| Post subject: | Modified Oil Pan for 60 - 66 A-Body |
Doc, I think it was you that said the F-Body oil pan could use a little "dent" at the centerlink area when used in a 60-66 A-body. I can't find the message when I search, but I was wondering if you had a picture of one that was modified to work correctly. Or even just an idea of the depth/ placement would be great. I'm getting one of these from Lou and would like to modify it before I get ready to put the motor in my Valiant. Thanks, Rick |
| Author: | Doc [ Thu Feb 18, 2010 5:02 pm ] |
Do you have the V - 8 centerlink on the Valiant... that helps alot. I will see if I can shoot and post a photo or two... seeing that I have nothing showing the mod work, currently in the "photo file". We are talking about the "369" pan, the blue one in the photo below. DD
| Author: | Dart270 [ Thu Feb 18, 2010 5:47 pm ] |
Yes, that is the pan Rick will get. The massaging could be done with a hammer with the pan bolted to a block, or a better way might be to cut a section out by the drag link and weld in a raised section. Lou |
| Author: | Rick Covalt [ Thu Feb 18, 2010 6:11 pm ] |
| Post subject: | Center link |
I do not have the V-8 center link. I was thinking if a knew the proper location I could heat the bottom of the pan with a torch and gently roll the area in with a piece of 2" pipe. I'm sure I can make it work. Rick |
| Author: | Dart270 [ Fri Feb 19, 2010 5:20 am ] |
Sounds like a good idea. Again, I would bolt to an old block to keep the rails straight. Lou |
| Author: | kesteb [ Sat Feb 20, 2010 7:29 am ] |
The left front corner of the sump also needs be dented in about 1/2" or it will hit the k-member. I just cut the piece out and weld in a flat piece of 16g steel. If you run the V8 center link you don't need to "massage" where the center link crosses over the pan, otherwise it is about a 1/2" dent. |
| Author: | Rick Covalt [ Sat Feb 20, 2010 8:48 am ] |
| Post subject: | Ebay pan |
Well, one showed up on E-bay so hopefully I can get that one. I'll still need yours Lou because the auction doesn't end until after the banquet I think. Thanks for the info, Rick |
| Author: | Dart270 [ Sat Feb 20, 2010 7:02 pm ] |
I'll bring to banquet in any case, and you return to me at Hagerstown if you don't need it. Lou |
| Author: | Doctor Dodge [ Wed Mar 10, 2010 11:11 pm ] |
Here are some photos showing both places where the "369" pan needs denting. The orange pan with the bigger / deeper dent in the rear section was used with the shallow SL6 centerlink. DD ![]() ![]() ![]()
| Author: | Rick Covalt [ Thu Mar 11, 2010 3:44 am ] |
| Post subject: | Thanks |
Doc, Thanks for the pictures. They will be good for future reference. I got the correct pan off of E-Bay Rick |
