| PowerPipe-DC (True Flow Header Design) https://slantsix.org/forum/viewtopic.php?t=39043 |
Page 1 of 12 |
| Author: | Mister Twister [ Thu Feb 18, 2010 8:13 pm ] |
| Post subject: | PowerPipe-DC (True Flow Header Design) |
Hello all this is my first stab a this style so let me know if we are on the right track. We will finish the install soon, stock kick down linkage, carb, choke pod, power steering, ect ect. Thank you for your input Don. |
| Author: | Joshie225 [ Thu Feb 18, 2010 8:29 pm ] |
Much better! Could use a longer, smaller diameter collector, but this is a big improvement. |
| Author: | Aggressive Ted [ Thu Feb 18, 2010 9:11 pm ] |
Much nicer! This one might be fun.....but you should incorporate a collector......a nice smooth transition is important! |
| Author: | madmax/6 [ Thu Feb 18, 2010 10:24 pm ] |
ALOT better,I agree with the others on the collector.You are listening very well.My hats off to you for the time and effort you are putting into this,Thanks.Guzzi Mark |
| Author: | Mister Twister [ Fri Feb 19, 2010 4:38 am ] |
Quote: Much better! Could use a longer, smaller diameter collector, but this is a big improvement. Thanks Joshua. How much longer and what size do you think the collector should be to help the slant class |
| Author: | Mister Twister [ Fri Feb 19, 2010 4:59 am ] |
Quote: Much nicer! This one might be fun.....but you should incorporate a collector......a nice smooth transition is important!
Ted this is alot of fun, |
| Author: | Mister Twister [ Fri Feb 19, 2010 5:17 am ] |
Quote: ALOT better,I agree with the others on the collector.You are listening very well.My hats off to you for the time and effort you are putting into this,Thanks.Guzzi Mark
These kind words from some of the top slanters is making me very happy. |
| Author: | Dart270 [ Fri Feb 19, 2010 5:24 am ] |
Are those 3" collectors, or bigger? 3" would be nice just for parts availability. These look quite nice and may be better than the Clifford shorties when you get a collector sorted out. Keep up the good work! Lou |
| Author: | Mister Twister [ Fri Feb 19, 2010 5:38 am ] |
Hello Dart270 yes these are standard 3" collectors. If you have a smooth shrinking pipe let say 3" to 2" 8" long connected to these, is that not the same as a longer collector? Just asking for my info |
| Author: | adiffrentcity [ Fri Feb 19, 2010 4:34 pm ] |
Quote: Hello Dart270 yes these are standard 3" collectors. If you have a smooth shrinking pipe let say 3" to 2" 8" long connected to these, is that not the same as a longer collector? Just asking for my info
I think that the answer is "yes" as most typical headers are designed this way.Your headers could be good for people who wanted to choose their collector length to suit their build. Could you give us a pic of where the pipes come together at the flange? |
| Author: | gmader [ Sat Feb 20, 2010 8:59 am ] |
Would you be willing to substitute a T3 turbo flange at the end, after the collector? How about stainless or ceramic coating as options? What kind of price are you shooting for? Greg |
| Author: | Dart270 [ Sat Feb 20, 2010 7:05 pm ] |
Personally, I think 3" collectors are the way to go anyway. You may want to get ahold of some other types of manifolds to make sure your pipes'll fit those (at least Offy and Clifford 4bbl and maybe Offy 2X1?). Also, let me know if you you would be interested in doing a single-outlet turbo manifold, either one off or to produce. Keep it up! Lou |
| Author: | emsvitil [ Sat Feb 20, 2010 8:50 pm ] |
Scroll down about 1/4 of the way. http://www.headersbyed.com/_collect.htm I think your collector should look like these. I think I remember using about a 15 degree merge angle until you get down to the size of the collector you want. If you want to get fancy have a triangular spike in the middle... |
| Author: | Mister Twister [ Sun Feb 21, 2010 4:27 am ] |
Hello all. This weekend is packed full of work for me, thanks for all the info. Wow sometime all we need is the right pic to make the light go on. I did post the first choke pod, started with the 1bbl and will be doing the 2bbl soon. Not enough time this morning to respond to all's response I will be back in here tonight or in the morning. See you soon Don. Have a good day |
| Author: | /6 Matt [ Sun Feb 21, 2010 5:01 pm ] |
Quote: Would you be willing to substitute a T3 turbo flange at the end, after the collector?
I'm with Greg on this one. Would you be willing to make them to sell after you perfect your design? How about stainless or ceramic coating as options? What kind of price are you shooting for? Greg |
| Page 1 of 12 | All times are UTC-07:00 |
