| 65 3 speed manual to A230 full syncro change out https://slantsix.org/forum/viewtopic.php?t=39079 |
| Author: | 65 Wagon [ Sat Feb 20, 2010 6:00 pm ] |
| Post subject: | 65 3 speed manual to A230 full syncro change out |
OK, I Have an A230 3 speed tranny (1970?) & I want to replace my existing 1965 3-speed non syncro. I scored a drive line from a 1974 Duster that was mated to a 904 auto. Since the drive line has a slip yoke, can I use this drive line with the A230 trans? I know the side levers on the trans & the linkage rods need to be lengthened, has anyone one this site done the conversion & have any pictures of the lengthened levers & linkages? Thanks, Benjamin |
| Author: | DusterIdiot [ Mon Feb 22, 2010 6:36 pm ] |
| Post subject: | ??? |
The driveline should work if the wheelbases of the vehicles are similar...A-230 and the A-904 should have the same slip yoke (I'd worry more about the post -1975 versions...) The next question is the shift rods: 1) Is this a column shift car? 2) Was the donor car a floor shift vehicle? -D.Idiot |
| Author: | 65 Wagon [ Mon Feb 22, 2010 8:25 pm ] |
Thanks for the response Duster Idiot. Sorry I wasn't more specific. The car that I am working on is a column shift. The donor A230 was also a column shift. I found a link on this site that mentioned that this swap could be done but the shift levers on the trans & the linkage rods would both have to be lengthened. I was hoping that someone had already done the swap so I could learn from their experience. |
| Author: | Doc [ Wed Feb 24, 2010 2:41 pm ] |
I have done this swap so it does work. You will also need a 66 A-Body speedo cable assembly. The way I did the linkage was to mount the 230 trans into the car and simply hold the linkage rods up to the case for reference. If I recall... I had to use the "flat" levers that came with the 230 trans and the forward shift rod was 'bent & adjusted' so it fit the lever The rear rod was just to short and had to have a section of material welded into it. One thing we noticed was the shorter 230 levers cut-down on the amount of "throw" up at the column shift lever. DD |
| Author: | 65 Wagon [ Wed Feb 24, 2010 6:20 pm ] |
Alright, not only did I get a reply...I got one from the Doc! Thanks, I kind of figured I would need to install it & just see what it took to make the rods fit. I'm thinking of getting an 8-3/4 from the same vintage A body duster (1974) To your knowledge is there a width difference or fitment issue? Thanks again for your help, Benjamin (SJ neighbor) |
| Author: | Doc [ Thu Feb 25, 2010 11:15 am ] |
66 thru 1972 A-Body 8 3/4 (5 on 4 "small" lug pattern) will install with all related factory parts and a 2 inch (appx) shorter driveshaft. If the car has 13 inch wheels, you need to make sure you have the correct rims to clear the larger 10" drums. This is a nice swap but be warned... A-Body 8 3/4 rears are not easy to find or cheap these days. DD |
