It is currently Thu Oct 08, 2026 8:26 pm
 Post subject: can i use this carb?
PostPosted: Fri Feb 19, 2010 10:12 pm
Car Model: 1972 Dodge Dart Swinger
Hi everyone!
I have a 72 swinger, 225, 1 bbl. i recently acquired a Rochester 2 jet (2gv) 2 bbl carb and wanted to know if and how i can use this carb. I know i need a 2bbl manifold but what else? thanks!
-angelo
1972 Dart Swinger, 225cid
PostPosted: Sat Feb 20, 2010 10:09 am
Hi Angelo. If you make a search in the forum using 'rochester', you come up with an awful lot of pages, if you search only for '2gv', you come up with some very interesting results. They tell the story of how mopar was short of Carters and actually used the Rochester 2gv! See here.
Olaf
Aspenized
 Post subject: ok....2nd question?
PostPosted: Sat Feb 20, 2010 11:57 pm
thanks for the reply! Sooo....do i need an adapter for it? would i use the same kickdown and throttle linkage setup of the supersix for the rochester? Thanks in advance.
-angelo
PostPosted: Sun Feb 21, 2010 6:55 am
It depends if the Rochester carb you have is in fact one of the ones that was made for Chrysler, or if it's off a GM vehicle. The ones made for Chrysler have Chrysler throttle and choke linkage arrangements. The ones for GM cars do not.
PostPosted: Tue Feb 23, 2010 6:57 pm
ok.....it came off a Chevy truck. i can't use it, can I?
PostPosted: Tue Feb 23, 2010 7:48 pm
Probably more trouble than it's worth.
PostPosted: Tue Feb 23, 2010 8:18 pm
Thank you for all of your help Dan!
-angelo
