It is currently Fri Nov 13, 2026 8:21 am
 Post subject: wiring seals
PostPosted: Fri Mar 05, 2010 12:29 am
so i was reading the new Classic Trucks mag that came in the other day and saw an article about these. http://www.spliseal.com/
1975 Plymouth Duster,225/6 2bbl. and duels, 904, 7 1/4
1986 Dodge Charger Shelby, 2.2 Turbo I, A525
PostPosted: Fri Mar 05, 2010 5:02 am
In my opinion, it is just a more expensive, and time consuming way to seal the splice, then a normal butt connector (which this system still uses) with sealant inside a heat shrink insulator.
PostPosted: Fri Mar 05, 2010 4:49 pm
I like the butt connectors without the insulation.
Crimp, solder, heat shrink... (RTV under heat shrink for a really good seal.
Only the thickness of the heatshrink larger in diameter.
