'73-'76 sway bar mounting?
https://slantsix.org/forum/viewtopic.php?t=39232
Author:  SlantSixDan [ Tue Mar 02, 2010 1:53 pm ]
Post subject:  '73-'76 sway bar mounting?
Looks like one (and only one) set of lower control arms for A-bodies in '73 and '74. No listing for "W/ anti-sway bar" vs. "W/O anti-sway bar". So how was the bar mounted in '73-'76?
Author:  Eric W [ Tue Mar 02, 2010 3:36 pm ]
Not sure, but probably something like the C body/isolated K frame B body set up, with the end links bolted to a bracket that wraps around the strut rod.
Author:  Reed [ Tue Mar 02, 2010 3:57 pm ]
Image OOOOH OOOOOOH I KNOW!
That's from my 74 FSM. Looks like a bracket welded onto the front of the lower control arm.
Author:  SlantSixDan [ Tue Mar 02, 2010 4:00 pm ]
Okeh, but then the question is whether all of the '73-'76 LCAs have the bracket…given that there's no separate part number given for "with" vs. "without".
Author:  Reed [ Tue Mar 02, 2010 4:04 pm ]
Nope. The LCAs on my brother's 74 Duster have no sway bar bracket. www.car-part.com lets you search for with or w/o sway bar brackets.
Author:  SlantSixDan [ Tue Mar 02, 2010 4:11 pm ]
Interesting. FPC fail! :roll:
Wonder what else is missing from cars not factory equipped with sway bar.
(it's peanut butter jelly time…)
Author:  Reed [ Tue Mar 02, 2010 4:16 pm ]
I would hazard a guess cars not equipped with a sway bar are missing two tabs welded to the LCA, the sway eliminator, two links, ten retainers, two sleeves, two supports, eight insulators, six nuts, four bolts, and four washers. :mrgreen:
Author:  SlantSixDan [ Tue Mar 02, 2010 4:19 pm ]
Hold still while I throw this end wrench at you.
I said hold still, dangit!
:lol:
Author:  Reed [ Tue Mar 02, 2010 4:24 pm ]
Author:  Jopapa [ Mon Mar 08, 2010 2:02 am ]
And a partridge in a pear tree.
Author:  zorg [ Tue Mar 09, 2010 9:44 pm ]
I agree with Reed. I had to add all that recently...
