wiring seals
https://slantsix.org/forum/viewtopic.php?t=39261
Author:  75duster [ Fri Mar 05, 2010 12:29 am ]
Post subject:  wiring seals
so i was reading the new Classic Trucks mag that came in the other day and saw an article about these. http://www.spliseal.com/
Author:  Charrlie_S [ Fri Mar 05, 2010 5:02 am ]
In my opinion, it is just a more expensive, and time consuming way to seal the splice, then a normal butt connector (which this system still uses) with sealant inside a heat shrink insulator.
Author:  emsvitil [ Fri Mar 05, 2010 4:49 pm ]
I like the butt connectors without the insulation.
Crimp, solder, heat shrink... (RTV under heat shrink for a really good seal.
Only the thickness of the heatshrink larger in diameter.
