It is currently Thu Nov 26, 2026 6:58 pm
PostPosted: Thu Feb 18, 2010 4:41 pm
Online
Doc,
I think it was you that said the F-Body oil pan could use a little "dent" at the centerlink area when used in a 60-66 A-body. I can't find the message when I search, but I was wondering if you had a picture of one that was modified to work correctly. Or even just an idea of the depth/ placement would be great. I'm getting one of these from Lou and would like to modify it before I get ready to put the motor in my Valiant.
Thanks,
Rick
PostPosted: Thu Feb 18, 2010 5:02 pm
Do you have the V - 8 centerlink on the Valiant... that helps alot.
I will see if I can shoot and post a photo or two... seeing that I have nothing showing the mod work, currently in the "photo file".
We are talking about the "369" pan, the blue one in the photo below.
PostPosted: Thu Feb 18, 2010 5:47 pm
Yes, that is the pan Rick will get. The massaging could be done with a hammer with the pan bolted to a block, or a better way might be to cut a section out by the drag link and weld in a raised section.
 Post subject: Center link
PostPosted: Thu Feb 18, 2010 6:11 pm
Online
I do not have the V-8 center link.
I was thinking if a knew the proper location I could heat the bottom of the pan with a torch and gently roll the area in with a piece of 2" pipe. I'm sure I can make it work.
Rick
PostPosted: Fri Feb 19, 2010 5:20 am
Sounds like a good idea. Again, I would bolt to an old block to keep the rails straight.
PostPosted: Sat Feb 20, 2010 7:29 am
The left front corner of the sump also needs be dented in about 1/2" or it will hit the k-member. I just cut the piece out and weld in a flat piece of 16g steel.
If you run the V8 center link you don't need to "massage" where the center link crosses over the pan, otherwise it is about a 1/2" dent.
 Post subject: Ebay pan
PostPosted: Sat Feb 20, 2010 8:48 am
Online
Well, one showed up on E-bay so hopefully I can get that one. I'll still need yours Lou because the auction doesn't end until after the banquet I think.
Thanks for the info,
Rick
PostPosted: Sat Feb 20, 2010 7:02 pm
I'll bring to banquet in any case, and you return to me at Hagerstown if you don't need it.
PostPosted: Wed Mar 10, 2010 11:11 pm
Here are some photos showing both places where the "369" pan needs denting.
The orange pan with the bigger / deeper dent in the rear section was used with the shallow SL6 centerlink.
 Post subject: Thanks
PostPosted: Thu Mar 11, 2010 3:44 am
Online
Doc, Thanks for the pictures. They will be good for future reference. I got the correct pan off of E-Bay
Rick
