| carb and intake question https://slantsix.org/forum/viewtopic.php?t=39271 |
| Author: | smithsteiff [ Fri Mar 05, 2010 5:04 pm ] |
| Post subject: | carb and intake question |
I have a 66 valiant with an auto trans and a 225 engine that is stock with only 30,000 original miles. I want to upgrade to a two barrel carb. I was thinking of either the Holley 2300 or 5200. I would use it on a used slant six two barrel intake with an adaptor for the Holley. Do you think that the 2300 350cfm is a better choice? I also have air cond. Is there any difference I need to know when choosing an intake? Will all two barrel intakes match up with my existing exhaust manifold? I have the cable style throttle which should work and I know I will have to modify my trans kick down and choke. Thanks for the info |
| Author: | Reed [ Fri Mar 05, 2010 5:10 pm ] |
For a stock 66 motor, I would recommend the Holley 2280 carb. The Super Six intake should work fine with A/C. |
| Author: | Rick [ Thu Mar 11, 2010 7:07 am ] |
there are two 2280's on ebay right now. bid starts at $ 100.00 or buy it now for $125.00 http://cgi.ebay.com/ebaymotors/New-Holl ... ccessories |
| Author: | SlantSixDan [ Thu Mar 11, 2010 7:45 am ] |
See this post for manifold ideas and link to less-expensive new Holley 2280. |
