F body manual steering
https://slantsix.org/forum/viewtopic.php?t=39308
Page 1 of 1
Author:  Tim Keith [ Sun Mar 07, 2010 8:40 pm ]
Post subject:  F body manual steering
Is the manual steering box for an A-body the same as a F-body?
Most of the f-bodies seem to have power steering.
Author:  Joshie225 [ Sun Mar 07, 2010 8:43 pm ]
Yes, the manual steering boxes interchange although the pitman arm may not.
Author:  Greg Ondayko [ Fri Mar 19, 2010 1:32 pm ]
Yes But as josh said The pitman arm poses problems.
Get a Manual box from a van say 73-77 and it' a direct bolt in without a pitman arm hassle.
Check steer and gear:
http://www.steerandgear.com/SteerandGear/index.html
They have them in stock - Good stuff from these dudes.
Author:  Tim Keith [ Fri Mar 19, 2010 9:26 pm ]
I came across a '52 Dodge B series "Pilothouse" 1/2 ton
with the Volare subframe installed. It has no steering or
motor. I am not going to purchase this truck, just curious
about an abandoned project and whether the K-frame
is installed correctly. The Volare setup fits very well and
does not appear hacked.
