| A-833-od https://slantsix.org/forum/viewtopic.php?t=3932 |
| Author: | Shad Gevers [ Sat Jul 20, 2002 8:15 pm ] |
| Post subject: | A-833-od |
I would like to swap a A-833-OD into my 65 dart. It currently has a 3 on the tree. Will any bell housing 1975 - 1987 fit my 65 225 slantie? Other then removing the 3 on the tree stuff do I need to do anything else to the floor? I know a guy that has a few od transmisions out of slant 6 trucks and volares. Any help would be great. Thanks, Shad G 65 dart gshad@ticon.net |
| Author: | ray [ Sun Jul 21, 2002 8:38 pm ] |
| Post subject: | Re: A-833-od |
: I would like to swap a A-833-OD into my 65 : dart. It currently has a 3 on the tree. Will : any bell housing 1975 - 1987 fit my 65 225 : slantie? : Other then removing the 3 on the tree stuff do : I need to do anything else to the floor? I : know a guy that has a few od transmisions : out of slant 6 trucks and volares. Any help : would be great. any /6 bell will bolt but make sure its an OD as the front bearing retainer centering hole is like 5 1/4" diameter(the biggest of them all). i.ve heard you can put the bearing retainer in a lathe and turn it down if you cant find an OD bellhousing. alot of the later 70's bells are drilled with both the 3 and 4 spd tranny bolt patterns. |
| Author: | Richard [ Sun Jul 21, 2002 9:39 pm ] |
: any /6 bell will bolt but make sure its an OD : as the front bearing retainer centering hole : is like 5 1/4" diameter(the biggest of : them all). : i.ve heard you can put the bearing retainer in : a lathe and turn it down if you cant find an : OD bellhousing. : : alot of the later 70's bells are drilled with : both the 3 and 4 spd tranny bolt patterns. I don't think you can turn down the bearing retainer as it would interfere with teh bolt pattern. Besides, you are better off getting the later model al bell housing |
| Author: | Dave Clement [ Mon Jul 22, 2002 8:55 am ] |
: I would like to swap a A-833-OD into my 65 : dart. It currently has a 3 on the tree. Will : any bell housing 1975 - 1987 fit my 65 225 : slantie? : Other then removing the 3 on the tree stuff do : I need to do anything else to the floor? I : know a guy that has a few od transmisions : out of slant 6 trucks and volares. Any help : would be great. I made this swap on my 68 Barracuda. The input bearing retainer on the OD trannies is much larger than the other trannies. You would be best off to locate a 6 OD tranny bell housing. The floor needs a BIG hole cut in it then covered over with a hump extension. The hole is about 18" long and goes from the center line of the hump down into the floor. If you can visualize it the 1/2 and 3/4 shifter rods are actually inside the car compared to the profile of the orignal floor. Anyway, you can make a hump extension or easier is to cut one from a 67-76 A-Body or purchase one new (they are advertised in the Mopar rags). These will likely needs some level of modification to work in your 65. Dave Clement Hot-Rod 6 dave.clement@motorola.com |
| Author: | bud L. [ Mon Jul 22, 2002 4:30 pm ] |
: I would like to swap a A-833-OD into my 65 : dart. It currently has a 3 on the tree. Will : any bell housing 1975 - 1987 fit my 65 225 : slantie? : Other then removing the 3 on the tree stuff do : I need to do anything else to the floor? I : know a guy that has a few od transmisions : out of slant 6 trucks and volares. Any help : would be great. : Thanks, Shad G 65 dart If you go to the later bellhousing, I don't think the torque shaft pivot lines up, so then you have to make some kind of a bracket for that. I went a different route. I took a big frt brg retainer and turned it down, and then took an early(63-66) 4spd bellhousing and bored it out to fit the turned down retainer. Problem solved. fglmopar@aol.com |
