| Plans for car (revised 10x's already) https://slantsix.org/forum/viewtopic.php?t=39326 |
Page 1 of 2 |
| Author: | /6 Matt [ Mon Mar 08, 2010 5:51 pm ] |
| Post subject: | Plans for car (revised 10x's already) |
For at least the 10th time I revised the plan for my 1970 Dodge Dart Swinger. As it stands it has a 225 Slant Six and an A-904 T-Flite transmission along with the stock 7 1/4" rear with 2.76 open gears. She needs alot of body work but other than the nessecary repairs, here's the plans. It's currently awaiting a Super Six conversion. Engine Dual 3" cold air intake 2-bbl Carter Carburettor 2-bbl Cast Iron intake (port and polished) Head work: .070" decked off, 3-angle valve job, 1.70" intake valve, 1.40" exhaust valve, port and polish job. Erson Cam #E47031 254/254 duration, 4.35/4.35 lift Cleaned up oil and water passages Exhaust Dual custom headers- 7/8" primaries, 2" collectors 2" X-pipe Dual 2" exhaust Dual 2" brand "X" turbo mufflers Drive Train A-833 4-speed manual O.D. transmission (2.50:1-1st, 1.70:1-2nd, 1:1-3rd, .64:1-4th) A-body pistol grip shifter (courtesy of gunslinger) A-body 8 3/4" rear with 3.91 posi gears A-body 8 3/4" BBP axles Suspension Small Block V8 torsion bars MP SS leaf springs, relocated inward to clear bigger tires Kyb Gas shocks Addco front+rear sway bar kit Polygraphite bushings Brakes 1973 and + BBP spindles (front) 1973 and + BBP sliding disc brake setup (front) Unknown rear brake setup BBP Wheels 15x6" Magnum 500 road wheels (front) 15x8" Magnum 500 road wheels (back) Body A-body 4-speed transmission tunnel Custom bolt-in subframe connectors Possibly a mini-tub if necessary to fit the wheels I want Still need imput on clutch and rear brake selection (preferably disc brakes). Could also use imput on anything else that I seem to have left out. |
| Author: | SlantSixDan [ Mon Mar 08, 2010 5:56 pm ] |
What makes you think you need or particularly want rear disc brakes...? What's the goal? Why custom subframe connectors when you can get ready-made bolt-in or weld-in ones for under $150/pair? Replace KYB shocks by Edelbrock IAS units Look into Hellwig sway bars instead of Addco Engine plan looks good Mopars do not have "Posi", they have Sure-Grip. |
| Author: | /6 Matt [ Mon Mar 08, 2010 6:06 pm ] |
Quote: What makes you think you need or particularly want rear disc brakes...? What's the goal?
I don't know, I guess it was just something that sounded good (wow that sounded bad). I take it your implying that 10' Drums would be sufficent?Quote: Why custom subframe connectors when you can get ready-made bolt-in or weld-in ones for under $150/pair? I didn't realize they run that cheap, i was just thinking home made to get around the price tag.Quote: Replace KYB shocks by Edelbrock IAS units I forgot to mention, the car is for cornering on hilly roads, not drag racing. Would you still recomend those? Or should I stick with the KYB's.Quote: Look into Hellwig sway bars instead of Addco What's wrong with Addco? Is there something I haven't heard about them like when I found out about Clifford Performance? Or is Hellwig just a better choice?Quote: Engine plan looks good Thanks, been planning for awhile now.Quote: Mopars do not have "Posi", they have Sure-Grip. Oh, I've heard them called that before but I didn't know they were strictly called Sure Grip.Thaks for the great imput! |
| Author: | /6 Matt [ Mon Mar 08, 2010 6:09 pm ] |
I forgot to mention the car is gonna be used for the occasional tire shredding and the seat-of-the-pants thrill rides through Burke County's curvey, hilly, roads. I also intend to embarrass a few ricers too. BTW: The budget is super-tight |
| Author: | SlantSixDan [ Mon Mar 08, 2010 6:36 pm ] |
Quote: I don't know, I guess it was just something that sounded good (wow that sounded bad).
Yup. Doing stuff just because it seems like a cool idea can drain your wallet in a big hurry. Beware feature creep, which is a fast and costly way to destroy a car and your enthusiasm for it. See here and here. You are definitely on the right track by drawing up plans, discussing and revising them before buying parts or taking things apart. Next steps are to prioritise the upgrades and budget time and money for them.Quote: I take it your implying that 10' Drums would be sufficent?
Absolutely yes. Put in the smaller rear wheel cylinders (see here) to fix the premature rear lockup these cars suffered from, and spend elsewhere the money and time you'd've wasted on rear discs.Quote: the car is for cornering on hilly roads, not drag racing. Would you still recomend those?
Definitely. As much better as KYBs are than parts store junk, the Edelbrock IAS are that much better than the KYBs...and they don't cost that much more, either.Quote: What's wrong with Addco?
Not a thing. They've been building good bars for years. So have Hellwig.
| Author: | SlantSixDan [ Mon Mar 08, 2010 6:46 pm ] |
Quote: the budget is super-tight
TILT! That changes everything. Unless you're planning on doing this list of upgrades over a period of many years, you are going to need to revise your plans downward a lot.(also: tubs and relocated springs? )
| Author: | madmax/6 [ Mon Mar 08, 2010 7:11 pm ] |
Tubs and relocated springs are only needed if your drag raceing and need big slicks to hook up,you do not need them.Guzzi Mark |
| Author: | DusterIdiot [ Mon Mar 08, 2010 7:17 pm ] |
| Post subject: | Um.... |
Quote: A-833 4-speed manual O.D. transmission (2.50:1-1st, 1.70:1-2nd, 1:1-3rd, .64:1-4th)
Where'd you get the custom OD tranny? Stock A-833 OD is 3.09 1st, 1.67-2nd, 1:1-3rd, and .73-OD |
| Author: | 75duster [ Mon Mar 08, 2010 10:14 pm ] |
as far as subframe connectors- if you want to keep from hacking the body much, go with the weld in ones. bolt in ones, while they will stiffen it up, still let alot of flex, and dont tie into the floor pans that i know of. whenever i get around to doing the ones in my duster, ill simply go and buy about 10 or 12 feet of 2"x3"x 1/8" rectulanger tubing and cut slits in the floor pan to fit it through, effectively tieing in both front and rear channels |
| Author: | /6 Matt [ Tue Mar 09, 2010 4:06 am ] |
Quote: Quote: the budget is super-tight
TILT! That changes everything. Unless you're planning on doing this list of upgrades over a period of many years, you are going to need to revise your plans downward a lot.(also: tubs and relocated springs? ) |
| Author: | /6 Matt [ Tue Mar 09, 2010 4:09 am ] |
| Post subject: | Re: Um.... |
Quote: Quote: A-833 4-speed manual O.D. transmission (2.50:1-1st, 1.70:1-2nd, 1:1-3rd, .64:1-4th)
| Author: | /6 Matt [ Tue Mar 09, 2010 4:15 am ] |
In regards to the mini-tubs and spring relocation comments, thats a last resort to try and fit 60 series tires out back. If they fit stock, then I'll leave it alone. If not, then the spring relocation will occur, and hopefully not the mini-tubs. Besides that, the rear fender wells are kinda rusty anyways so... I know you say "why 8" rims with 60 series tires?" I just like the look of big meats. |
| Author: | DusterIdiot [ Tue Mar 09, 2010 5:22 am ] |
| Post subject: | Nope... |
Quote: Can you not swap transmission ratios like you can in a rear end?
Uh, no... the counter shaft gear is a solid set, so you are stuck with the OD ratio set or the straight box ratio set... if you're going to blow the $$$ on the Gear Vendor set, you might as well go T-5 conversion at this point.-D.Idiot |
| Author: | Aggressive Ted [ Tue Mar 09, 2010 12:55 pm ] |
Matt, You forgot to include recurving your distributor on the engine build. It makes a huge difference even on a stock motor. I drive on allot of hilly back country roads every day to work and back. The Edelbrock IAS shocks are the best if your pushing it. They are amazing....I didn't think a shock could make that much difference. I am running the biggest Hellwig bar on the front. Also .892 V8 torsion bars on the front and 6 leaf rears. P215 60's on the front and P235 or P225 60's on the rear, BF Goodrich T/A radials, on 7" rims. They track like a cat. Great in the snow.....and ice. |
| Author: | SlantSixDan [ Tue Mar 09, 2010 1:05 pm ] |
Quote: BF Goodrich T/A radials, on 7" rims. They track like a cat.
Doesn't that make safety problems in traffic, Ted, if every time someone uses an electric can opener your tires hear it and the car veers off in that direction? |
| Page 1 of 2 | All times are UTC-08:00 |
