| dodge charger dash gauges "floating" https://slantsix.org/forum/viewtopic.php?t=39336 |
| Author: | 63pushy [ Tue Mar 09, 2010 8:55 pm ] |
| Post subject: | dodge charger dash gauges "floating" |
My nephew has a 70 dodge charger. He had the gauges reconditioned and after I reinstalled the cluster (that sucked, big time) the needles just float around. Could it be a bad dash voltage regulator? I did run a fresh ground from the dash cluster to a good ground. In a (probably) related story, the car just doesn't charge at anything like idle. The alternator has been rebuilt, and the voltage regulator has been replaced. Any guesses? I am ready to give up. |
| Author: | KBB_of_TMC [ Wed Mar 10, 2010 9:07 am ] |
Check the dash ground and feed to the voltage limiter carefully. You can put a test light on the temp sender connection - it ought to come on at full +12V, then start blinking on and off ~ 2Hz-ish (not entirely regular is normal). If you see much less than +12V when it's on, you've got a poor connection on the hot side. If the problem gets worse with dash lights on bright, it is definitely a ground problem. |
| Author: | 63pushy [ Wed Mar 10, 2010 6:08 pm ] |
| Post subject: | thanks |
KBB, thanks a lot. I will check that as soon as I can get over there... |
