It is currently Thu Nov 26, 2026 7:27 am
 Post subject: Rocker Arm Oiling
PostPosted: Thu Mar 11, 2010 3:57 pm
Still fighting this battle. How much oil should be coming out of oil holes in the rockers? Running RAS 1.6 non roller. I know that you can't get much through a .070 space in the rear bolt hole, but I expected to see oil flinging everywhere when looking in the fill cap hole. Does not look like it is making it to the valve tips. Is anyone still making a spray bar for the valve cover? How much oil do you need to spray? Any info would be appreciated.
Thanks
Phil
PostPosted: Fri Mar 12, 2010 5:59 am
You wont see oil spraying or splashing around on the valve train. You should see a good coating of oil on All the moving parts. Oil should be dripping onto the valve tips as well.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
