| How much oil to the rocker arm? https://slantsix.org/forum/viewtopic.php?t=39366 |
| Author: | pemercie [ Thu Mar 11, 2010 3:29 pm ] |
| Post subject: | How much oil to the rocker arm? |
How much oil should be flowing out the holes on a RAS 1.6 shaft? Still not sure if this is right. 45 psi at idle. I know that you can't get much through .070 at the rear bolt but it still worries me not to see oil flinging everywhere when I look inside the oil filler cap. Does not seem to make it to the springs. What about spraying? Is anyone making a valve cover with a spray bar yet? Any details about a sprayer would be apprieciated. Thanks Phil |
| Author: | 66aCUDA [ Fri Mar 12, 2010 6:01 am ] |
Do a search for "oil spray bar" Doc did one on his engine. There have been others as well. Frank |
