| 1964 trans https://slantsix.org/forum/viewtopic.php?t=39377 |
| Author: | hydrive1953 [ Thu Mar 11, 2010 11:03 pm ] |
| Post subject: | 1964 trans |
I have a 1964 Plymouth trans from or out of a car with a slant/6 what kind would it be, it is a auto trans three speed. I don't have any of the info(numbers) for the trans with me. Just was wondering what the hell I have hear. I just want a extra for my 1975 Dodge Dart. I hope this one will work, if so I am going to re-build it and have it ready. It came from a running but RUSTY VERY RUSTY CAR! |
| Author: | Charrlie_S [ Fri Mar 12, 2010 4:43 am ] |
A 1964 slant six auto trans is a 904. It will not be an easy swap into any mopar 1966 and later. The 64 trans is "cable shifted", has a flage on the rear of the tail shaft, and a different speedo hookup. It also has a smaller input shaft diameter, so needs the torque converter that goes with the trans, but that has a smaller pilot then the register in the end of the 68 and up engines, so a small adapter is needed. You would be much better off finding a 68 or later 904 trans. The later trans will be a direct bolt for bolt replacement. |
| Author: | hydrive1953 [ Fri Mar 12, 2010 11:04 pm ] |
thanks for the info. I will dump it then I thought I could use it in my car ooh--well |
| Author: | Charrlie_S [ Sat Mar 13, 2010 3:47 am ] |
Quote: thanks for the info. I will dump it then I thought I could use it in my car ooh--well
I would suggest you offer the trans to members of the site (or other Mopar sites), rather then just "getting rid of it". Where are you located?
| Author: | hydrive1953 [ Wed Jul 28, 2010 11:34 pm ] |
I am in Elizabeth,IL and if you want I will trade for a trans that will work in my 1975, or sell it for $75.00 with the complete shift parts (dash part & cables) |
| Author: | Charrlie_S [ Thu Jul 29, 2010 4:57 am ] |
If you were closer, I would work a trade, but shipping that heavy an item is a deal killer. |
