It is currently Sat Oct 24, 2026 12:12 am
 Post subject: super six
PostPosted: Sun Jul 21, 2002 9:46 pm
i am going junk yard shopping this week and looking for a super six system. i was wondering what cars they were found in and everything i need to make sure it runs correctly. i have a 68 barracuda with a 225. i am also planning on buying a new Carter BBD 2bbl carb instead of getting the old one. thankyou
harleyd008@aol.com
 Post subject: Re: super six
PostPosted: Sun Jul 21, 2002 10:44 pm
Take the old one a rebuild it. The new ones are way out of line and hard to order. Rebuilding is the way go.:
: looking for a super six system. i was
: wondering what cars they were found in and
: everything i need to make sure it runs
: correctly. i have a 68 barracuda with a 225.
: i am also planning on buying a new Carter
: BBD 2bbl carb instead of getting the old
: one. thankyou
safehavenhi@yahoo.com
PostPosted: Mon Jul 22, 2002 1:34 am
: i was wondering what cars they were found in and everything i need to make sure it runs
Adam, start by looking in Aspens/Volares, especially wagons, then move on to the larger cars, including vans and pickups.
You will need, at minimum;
Intake & carb (may as well take intake/exhaust assy.)
The air cleaner/filter assy.
The trans kickdown linkage (if yours is auto trans, manual trans doesn't use)
Make sure you get the throttle cable brackets, too, and you might even want to snag the cable.
Hint; hoard the intake/exhaust mounting nuts & washers. (the triangular and brass ones) They're getting a little hard to come by.
Roger
GTS225@aol.com
PostPosted: Mon Jul 22, 2002 10:09 am
: Adam, start by looking in Aspens/Volares,
: especially wagons, then move on to the
: larger cars, including vans and pickups.
thanks for the info... for the Aspens/Volares, im looking for the late 70's right is that the same with the rest of the cars and pickups. Are some of them early 80's.
harleyd008@aol.com
PostPosted: Mon Jul 22, 2002 10:30 am
: thanks for the info... for the Aspens/Volares,
: im looking for the late 70's right is that
: the same with the rest of the cars and
: pickups. Are some of them early 80's.
Adam, yeah....sorry....I neglected to give you a year/vintage window. Mid/late 70's to mid 80's. the slant "died" in somethng like '86, and was last put in pickups and vans. Oh, and take off the air cleaner and look down through the carb throat to verify for the two-barrel. Some of those carbs look like a one-barrel from the outside.
Roger
GTS225@aol.com
PostPosted: Sat Jul 27, 2002 11:38 am
: Take the old one a rebuild it. The new ones are
: way out of line and hard to order.
: Rebuilding is the way go.: i am going junk
: yard shopping this week and
I suggest you get a carb with the original aluminum tag on it if you can. The rebuilders usually remove the tag, so if you get one with the tag, it probably has not been rebuilt (and screwed up) yet. Rebuilders for the parts shops tend to mix and match parts and that causes problems. If you take an original to a good rebuilder yourself then you will probably end up with a better carb. I found 2 with the original tags in Florida and had a professional rebuilder go through one of them. It came out like new.
Chuck
webmaster@omnipages.com
Users browsing this forum: Ahrefs [Bot] and 12 guests
