| auto to manual wiring ?? https://slantsix.org/forum/viewtopic.php?t=39398 |
| Author: | Volare4life [ Sat Mar 13, 2010 6:55 pm ] |
| Post subject: | auto to manual wiring ?? |
So I will be swaping a T5 into my '79 F-Body, and just need to know how to wire the Neutral safety switch to the T5, -Mike |
| Author: | emsvitil [ Sat Mar 13, 2010 8:33 pm ] |
I wouldn't bother............ Ground the wire, or make sure it's not grounded.... Whatever way lets you start the engine.... |
| Author: | Charrlie_S [ Sun Mar 14, 2010 5:41 am ] |
You could wire a micro switch to the clutch pedal, For a clutch safety. Bring the single wire from the start relay, to the switch and the other side of the switch to ground. The switch should be normally open. PS: the wire from the relay at the transmission connector is the middle one. |
| Author: | Volare4life [ Sun Mar 14, 2010 8:38 am ] |
well I have a pedal (single ) from a 1990 Nissan 300ZX, with the neutral safety switch attached, so I take the middle wire from the trans connector and connect it to one of the wires on the neutral safety switch, and just ground out the other correct ? What about reverse lights ? -Mike |
| Author: | Charrlie_S [ Sun Mar 14, 2010 11:28 am ] |
Quote: well I have a pedal (single ) from a 1990 Nissan 300ZX, with the neutral safety switch attached, so I take the middle wire from the trans connector and connect it to one of the wires on the neutral safety switch, and just ground out the other correct ? What about reverse lights ?
Yup, that will work. Not all that familia with the 4 sp trans, but if I remember correctly, there is a switch on the rear of the trans main case. Just connect the two remaining wires from the auto trans connector (two outboard wires) to this switch.-Mike See, it is not necessary to be a "rocket scientist". |
| Author: | Volare4life [ Sun Mar 14, 2010 3:37 pm ] |
So true, I hate reading wiring diagrams, stuff drives me nuts lol, Thanks again Charrlie !! -Mike |
