It is currently Thu Nov 26, 2026 2:06 am
 Post subject: timing marks message 2
PostPosted: Fri Mar 12, 2010 3:55 pm
Thanks everyone for your help. I looked at my cover and can see form the message sent by Ceej that the tab on mine has been removed. If anyone can help me find a replacement (either the tab or the whole cover), I'd be indebted. Also, just to confirm, any other photos would be appreciated.
thanks
dan
PostPosted: Fri Mar 12, 2010 4:36 pm
Check this photo under the "Articles Section" on the front page "Main Seal Installation and Oil Pan Sealing" .
PM sent for your email.
I have a picture of my 74 timing tab. :)
PostPosted: Fri Mar 12, 2010 5:22 pm
You could make your own out of stiff wire. loop it around two of the cover bolts and with the engine at top dead center bend the wire to indicate tdc on the harmonic balancer. Best done with head off and a dial indicator. Then use a degree wheel to mark off 5 degrees points both before and after. Or what ever degree points you want/need. Repeat as needed.
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
 Post subject: timing chain cover
PostPosted: Sat Mar 13, 2010 1:16 pm
I think I'm having trouble getting private messages out; they seem to stay in the outbox.
it's: dan.tanner@ns.sympatico.ca
PostPosted: Sat Mar 13, 2010 2:15 pm
Ok, picture of timing tab sent.
Where the hole is in the middle is zero, then 10 degrees each way before and after. Let me know if you need more...
 Post subject: Re: timing chain cover
PostPosted: Sat Mar 13, 2010 2:48 pm
hello,
yes that is correct they stay there until the recipient reads the message,then it will appear in the sent box.
regards,Rod :D
 Post subject: timing cover
PostPosted: Tue Mar 16, 2010 3:59 am
Thanks all.
Located one in Ontario; being sent here now.
dan
