It is currently Mon May 18, 2026 7:09 pm
PostPosted: Sat Nov 24, 2012 2:58 am
I am restoring a 62 Signet GT 2 door coupe. The rear quarter window rubber is unusable as it is badly perished/damaged.
I am after a solution for a replacement window rubber. Any ideas?
NOTE: The rear quarter vent window and window rubber on the 2 door coupe and 2 door sedan is a different size to the 4 door sedans - they are bigger.
Thanks, Peter
PostPosted: Fri Nov 30, 2012 7:39 pm
Thanks, Peter
Hi Peter,
I'm working on the same car and was able to get the rubbers from Pentastar... www.pentastarparts.com,au I wasn't able to get the rubbers to accept the original stainless but felt it was better to have good weather stripping than the trim. Contact them and make sure you get what you want. Good luck with your Toad!
Regards,
John Brayton
1962 Plymouth Valiant
