| Ign Timing https://slantsix.org/forum/viewtopic.php?t=39447 |
| Author: | MI6 [ Wed Mar 17, 2010 5:10 pm ] |
| Post subject: | Ign Timing |
I thought I would try to adjust the timing today on my 71 by using a vac gauge (my timing light is broken). I found the dist was turned as far counterclockwise (advanced?) as it would go and the vacuum was a little low, around 15 but fairly steady. Any clockwise movement caused the engine to run rough and then die. I can detect no vac leaks. Could the dist be off by a tooth or is this within normal setting? The car, a Satellite, seems a little sluggish and underpowered but this is my first slant six so I have nothing to compare it to. The axle is 2.94. |
| Author: | SlantSixDan [ Wed Mar 17, 2010 5:27 pm ] |
The timing cannot be set accurately with a vacuum gauge. You need to fix or replace your timing light. |
| Author: | Doc [ Wed Mar 17, 2010 5:30 pm ] |
Fix, borrow or get another timing light... Before moving a tooth on the distributor, try loosening the bolt on the bottom side of the plate, to see if you can get more advance. DD
| Author: | MI6 [ Wed Mar 17, 2010 5:43 pm ] |
Didn't have a clue that bolt was there. I'll give it a try. Thanks. I do need to get another timing light. Are the ones that show rpm etc. worth the extra money? |
| Author: | DusterIdiot [ Wed Mar 17, 2010 7:56 pm ] |
| Post subject: | Yep... |
Quote: Are the ones that show rpm etc. worth the extra money?
I paid $100 for a dial back digital with Tach...As a few local members can vouch it's paid for itself. Between it and a vacc. gauge super tuning an engine is fairly easy... -D.Idiot |
| Author: | KBB_of_TMC [ Thu Mar 18, 2010 10:10 am ] |
I recently bought an adjustable timing light (made in Taiwan) from Harbor Freight. The light is bright and its calibration is right on; I think it cost ~$25 on sale. I also bought their CenTech digital tach/dwell (made in China); unfortunately, I've been unable to get it to work very well at all and I'd recommend avoiding it. |
