| Clifford headers https://slantsix.org/forum/viewtopic.php?t=39525 |
| Author: | hellion_locdogg [ Mon Mar 22, 2010 11:18 pm ] |
| Post subject: | Clifford headers |
Do I have to go back to a manual steering box on my '63. The front header hits the inner top of the gear box... What to do? ,Cliff |
| Author: | /6 Matt [ Tue Mar 23, 2010 4:31 am ] |
First of all is your name really Cliff? That's a cool coincedence. Second of all, worst case scenario is that your might have to take it to a local exhaust shop and see if they can re-bend it a little. |
| Author: | Charrlie_S [ Tue Mar 23, 2010 5:14 am ] |
Make sure your motor mounts are in good condition, and haven't sagged. Maybe add a little bit of a shim to the driver side mount. |
| Author: | hellion_locdogg [ Tue Mar 23, 2010 6:17 am ] |
Motor mount was my thinking as well. Mybe some tweeking. Thanks ,Cliff (real name) |
| Author: | /6 Matt [ Tue Mar 23, 2010 1:43 pm ] |
Quote: ,Cliff (real name) sweet...
| Author: | Doc [ Tue Mar 23, 2010 1:56 pm ] |
We see this problem in the 60-62 A- Body chassis. On the last one of those, we removed the driver's side motor mount nut, jacked the engine up and stuck a piece of 2X4 (actually 1 1/2 thick) into the interference location, lowering the engine onto the inserted "shim". Then we heated the header tubes with a tourch, did a little "pushing and prying", until the engine/mount re-settled onto the K-member... with the shim still in place. Jacked-up the engine, removed the wood shim, lowered the mount back into position and we had clearance. DD |
| Author: | hellion_locdogg [ Tue Mar 23, 2010 2:05 pm ] |
" into the interference location" I take it you mean between header and gear box? If so, easy I have a torch. ,Cliff |
