| Water Neck Interchange? https://slantsix.org/forum/viewtopic.php?t=39533 |
| Author: | Greg Ondayko [ Tue Mar 23, 2010 5:25 pm ] |
| Post subject: | Water Neck Interchange? |
What will swap with the stock Slant water neck?? I want to get one that is "Straight Out" rather than the stock / factrory 90* angle. Lou, I am getting that summit crossflow for ruster, like you have in the '64 What did you use? (for a water neck?) I need the straight up water neck to route the upper rad hose to the left side of the engine bay.( for the crassflow rad.) I need a similar one to get the thing (ruster) running. I am looking for one on summit now, but there's a lot to choose from. I have busted 2 older Rads putting on my electric fan, so it's time to upgrade. I was going to get this rad anyway...so might as well spend the dime now. Thanks all sages for you help! Greg |
| Author: | Fopar [ Tue Mar 23, 2010 6:18 pm ] |
Would the one from a 318 fit?? |
| Author: | 4speed [ Tue Mar 23, 2010 6:23 pm ] |
Or a 440? |
| Author: | Romeo Furio [ Tue Mar 23, 2010 6:40 pm ] |
| Post subject: | neck |
The 318 and 440 are the same but the slant takes a smaller T- stat(diameter). Now I don't know what year they changed the small block late model intake but it may be a match for the size of the slant. They are smaller and are stamped steel.May work. |
| Author: | Greg Ondayko [ Tue Mar 23, 2010 7:26 pm ] |
Would This work? http://summitracing.com/parts/DCC-44520 ... refilter=0 it's for the 1979- 93 Small blocks. My main concern is the Bolt holes lining up and of course the t'stat Registereing in the housing correctly. Greg |
| Author: | 4speed [ Tue Mar 23, 2010 7:39 pm ] |
You could check around a see which engines use the same thermostat gasket-that would let you know what fits. |
| Author: | Greg Ondayko [ Tue Mar 23, 2010 7:50 pm ] |
Thanks! Yep 79 and newer LA Engines are the same as the slant. 78 and older are the bigger 2 1/4 T-stat Housing. Greg |
| Author: | 66aCUDA [ Wed Mar 24, 2010 7:36 am ] |
Greg PM me if this works well as I have the same needs. Thanks, Frank |
| Author: | MenkeMoose [ Wed Mar 24, 2010 8:39 am ] |
I bought one at Summit that was supposed to fit the '79 and later bb, but the hole spacing was still too wide. From what I could tell, none of those sold at Summit have the correct hole spacing for a /6. Someone had mentioned in an earlier post a chrome one from Mopar Performance that is supposed to fit, but I haven't located it yet. Moose |
| Author: | Romeo Furio [ Wed Mar 24, 2010 4:59 pm ] |
| Post subject: | water neck |
the 79 up small block chrome one from mopar is #P4452025 stamped steel. |
| Author: | madmax/6 [ Wed Mar 24, 2010 7:30 pm ] |
I went to Pick a part and just kept looking till I found what I needed,pulled mine off a Ford.Didnt pay attention to what model or year,know it had a big heavy hood cause it came down on my head and put me on the ground.Guzzi Mark |
| Author: | Dart270 [ Wed Mar 24, 2010 9:02 pm ] |
Yep, '79 up Mopar SB V8 is the one I have. Lou |
| Author: | Greg Ondayko [ Thu Mar 25, 2010 1:29 pm ] |
Quote: Yep, '79 up Mopar SB V8 is the one I have.
Lou yup Summit charges a hefty price for the thing, but it fits. The holes are 5/16" on the stamped piece. I just drilled them out to 3?8" for the slant. Will work fine. Probably one from a boneyard LA engine post 79 will work for a lot cheaper! Greg |
| Author: | Valleyant [ Thu Mar 25, 2010 4:32 pm ] |
I have to dig around the garage for some comparison but a 2.2/2.5 4cylinder style out let may work. nico |
