| BWWaaaahhaaaahahahaaaaaa!!!!!!!!!! I'm delusional!!!! https://slantsix.org/forum/viewtopic.php?t=39534 |
| Author: | slyder383 [ Tue Mar 23, 2010 5:58 pm ] |
| Post subject: | BWWaaaahhaaaahahahaaaaaa!!!!!!!!!! I'm delusional!!!! |
MAybe I should get rid of it before I do something................CRAZY?!?! I got a good supercharger and intercooler from a Chevy Cobalt......And Have been dreaming about my 65 D100 with the SC/. I have read through some topics but am at a loss. Heavy modifications no matter what, but I have an idea every year or two! Eaton m62. What would you do??? |
| Author: | kipamore [ Tue Mar 23, 2010 6:10 pm ] |
Dumb idea #1: Run it off the driveshaft, blowing thru the carb Dumb idea #2: Mount it to the A/C compressor bracket, belt drive it, blow it thru the carb. Dumb idea #3: Mount it on the hood, mate it to a starter motor, hit it only when you want it Mad Max style Dumb idea #4: Mount it to a mountain bike, hang the mountain bike tire out the window to the ground when you want it to kick in. Dumb idea #5: Mount it on top of the air cleaner. Mount a propeller to the front of it. The faster you drive, the faster it spins. I'm spent. |
| Author: | slyder383 [ Tue Mar 23, 2010 7:00 pm ] |
Dumb idea #1: Run it off the driveshaft, blowing thru the carb (Thus requiring a total overhaul of the brake system. cuz the faster the driveshaft turns, the more boost/ speed. and no matter what it will go faster, n faster, n I cant stop goin faster, n faster) Dumb idea #2: Mount it to the A/C compressor bracket, belt drive it, blow it thru the carb. ( requiring I install A/C on my 65, wich is a total pain) Dumb idea #3: Mount it on the hood, mate it to a starter motor, hit it only when you want it Mad Max style (I'm not sure my charging system/ Battery could handle the load, but would a cranking handle lessen that effect? And would the hood ribbing support the torqe loading?) Dumb idea #4: Mount it to a mountain bike, hang the mountain bike tire out the window to the ground when you want it to kick in. (I like this idea! I live in the mountains!) Dumb idea #5: Mount it on top of the air cleaner. Mount a propeller to the front of it. The faster you drive, the faster it spins. ( Now I'm confused? At high sppeds, This would seem to cause excessive lift? I am not into aeronautic's, just old /new auto's) |
| Author: | Rick Covalt [ Wed Mar 24, 2010 4:07 am ] |
| Post subject: | Nitrous! |
Don't forget, that whatever dumb idea you choose, that you must then add a 300 shot of nitrous to it. That will smooth out all the rough spots and make all that labor and engineering worth your effort! Rick |
| Author: | 66aCUDA [ Wed Mar 24, 2010 7:28 am ] |
You DO know I sell the Aussie Speed Blower Manifolds with an adapter plate for the Eaton SC right? Im using the M90 version. Frank |
