| Head Gasket Source for Aluminum Block Slant Six? https://slantsix.org/forum/viewtopic.php?t=39542 |
| Author: | Walter Lee Jackson [ Wed Mar 24, 2010 2:11 am ] |
| Post subject: | Head Gasket Source for Aluminum Block Slant Six? |
Are these available anywhere? TIA --Walt Jackson |
| Author: | Dart270 [ Wed Mar 24, 2010 9:01 pm ] |
Try Kanter Motor Products. Lou |
| Author: | Charrlie_S [ Fri Mar 26, 2010 5:47 am ] |
Quote: Try Kanter Motor Products.
Can someone give me the part numbers for the head gasket and the rear seal? Also the engine set? Both OEM and after market. I will check my source, and see if any are available.
Lou |
| Author: | Walter Lee Jackson [ Fri Mar 26, 2010 8:28 am ] |
Here are the OEM numbers out of the Chrysler parts manual for the complete gasket set: 2240 628 up to engine number T-22-4-1 B2240 628 after engine number T-22-4-1 Thanks. --Walt Jackson |
| Author: | 62 alum [ Fri Mar 26, 2010 9:06 am ] |
| Post subject: | fel-pro gasket |
The # I have for the head gasket set is Fel-pro HS 8000 SH. These are old sets and I don`t no is the number is still valid. |
| Author: | SlantSixDan [ Fri Mar 26, 2010 11:38 am ] |
Misprint. There is no such part number as "B2240 628", and never was. The part number is 2240 628. Fel-Pro number was indeed 8000 (FS8000SB for full set, HS8000SH for head set). Victor or McCord (don't recall which) number was 1184. It's not too hard to find these gaskets; last time I checked, Gerald Letieri and the other gasket specialty houses advertising in Hemmings had them in stock. |
