It is currently Fri Jan 02, 2026 2:10 pm
 Post subject: Fuel Jet Help
PostPosted: Sat Feb 20, 2010 11:28 am
my carb is a 1945 holley and it has a #199 main jet. When I get it emissioned here in utah it is a little rich and won't pass. I was wondering what jet you would recomend to make it a little leaner since i can't find any numbers like the one on my jet to go off of.
 Post subject: 1945 jet sizes
PostPosted: Sat Feb 20, 2010 11:43 am
That is the wrong #. If it were true that jet would be huge! In 1974 they came with a 612, jet a close tolerance 61. You could install a 60 all the way down to a 58 to lean it out.
PostPosted: Sat Feb 20, 2010 12:03 pm
I wonder if that "199" is really an upside-down "661", which would be an enormous jet.
PostPosted: Sat Feb 20, 2010 12:34 pm
The #1 can't be upside down cause it looks just like this (1) not just a one.
I have done the HEI mod and 2 1/2 inch exhust but not much else. I am at an elevation of about 4500 feet. Can I try any of those jets as trial and error or does anyone have an educated guess as to which one I should start with. Appreciate all the help you guys give.
PostPosted: Sat Feb 20, 2010 12:37 pm
Well, start with a new #58 jet (you can't buy the 3-digit jets in the aftermarket) and see how you go with it. Or if the whole carburetor's questionable, install a better one.
PostPosted: Sat Feb 20, 2010 12:46 pm
What Carbs would you recommend if I went with a new one
PostPosted: Sat Feb 20, 2010 1:00 pm
Send me a PM with full detail about your car and I'll see what I have in stock. Do not buy a "remanufactured" carburetor; they're junk.
PostPosted: Mon Mar 29, 2010 3:20 pm
The Jet that had a 199 on it when measured was close to a 64. I put a 58 in it and it passed emissions perfectly. Thanks guys.
 Post subject: Lol...
PostPosted: Mon Mar 29, 2010 6:14 pm
Now that you have passed emissions...stick a #60 in it and drive it with some power...
:wink:
PostPosted: Tue Mar 30, 2010 6:33 am
I've already swapped it back over and I love this truck
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 9 guests
