| Any one ever try to take apart diff and build a spool/posi https://slantsix.org/forum/viewtopic.php?t=39634 |
| Author: | dustertech2000 [ Mon Mar 29, 2010 3:18 pm ] |
| Post subject: | Any one ever try to take apart diff and build a spool/posi |
ok i have a 7.25 that i've been looking for a posi for, for a while and i dont have to money to get a bigger rear and have already put money in rebuilding the 7 with 3.55 gears. i was wondering if any one have heard of or thought of a way to convert open to posi with out welding spyders together, i'm looking to remove the spyders and some home pin or do something. anybody???? |
| Author: | Romeo Furio [ Tue Mar 30, 2010 2:39 pm ] |
| Post subject: | spool |
Now this is old school, VERY old school,like front engine dragster old. I have never done it but guys shimmed the spyders till they locked tight on 8 3/4 open rears for a home made spool, locker, what ever you want to call it. I am sure it takes alot of trial and error. I am not sure how long it lasts or if I had the guts to try it. |
| Author: | Doc [ Tue Mar 30, 2010 3:11 pm ] |
It is not hard to do... Just doube-up the shims that go behind the side & spider gears. For even more "drag" on the spider gear assembly, you can install a motor cycle valve spring in-between the two spider gear faces, then push the cross-shaft thru the spring to hold it in place. If done "right" A tightly shimmed open diff will spin both wheels in a straight line and on wet surfaces. It will not do drifter type slides or doughnuts. I find that doing this mod turns the gear oil black faster and in the case of a 7 1/4, will break weak spider gears. DD |
| Author: | dustertech2000 [ Tue Mar 30, 2010 3:29 pm ] |
do if i'm going to try to shim the spyders tighter i should start stocking up on spyder gears for when they break?? by doing this will i get enough of a posi ish rear to when running slicks at the strip i will hook hard. |
| Author: | Doc [ Tue Mar 30, 2010 3:39 pm ] |
A "hard hook" and a open carrier 7 1/4 don't "mix". Save yourself some trouble and find a stronger rear axle assembly to work with. DD |
| Author: | dustertech2000 [ Tue Mar 30, 2010 4:00 pm ] |
yeah i know i'm working on tring to get a 8 1/4 or 8 3/4 but dont have the $$ right now. i already rebuilt the 7 with 3.55s and did new brakes and all that stuff. really want to find a 7 1/4 sure grip, bought one years ago but it was completly distroyed. |
| Author: | Romeo Furio [ Tue Mar 30, 2010 5:45 pm ] |
| Post subject: | shims |
Thanks Doc, I was hesitant on that post thinking that most would have thought I was nutz!! |
| Author: | Doc [ Wed Mar 31, 2010 8:52 am ] |
I am just as "nutz"... seeing that I tend to go "out of my way" to try a lot of those "who knows" ideas... just to end-up with broken parts... but now I know. I will say that a tightly shimmed "open" 8 3/4 works pretty well. I am currently running one, a tightly shimmed 3.07 ratio and it reduces the amount of one wheel "sit there & spin - no forward movement" type action. The tight spider shimming also reduces the amount of backlash in the assembly so there is not a loud "clank" when putting the car in gear. The big difference... the 8 3/4 open carrier and spider gears are a lot bigger and stronger then the 7 1/4 parts. DD |
| Author: | dustertech2000 [ Wed Mar 31, 2010 3:08 pm ] |
yeah i'm probly just going to leave mine alone cuz i know its weak, i will continue search for cheaper 8 3/4, i screwed up years ago, had the chance to get a full drum to drum brand new everthing 3.55 posi 8 3/4 at carlisle for 800 bucks. |
| Author: | Romeo Furio [ Wed Mar 31, 2010 6:22 pm ] |
| Post subject: | 8 3/4 |
That still is the going price. Found one at MATS swap meet for $700. PM me and I can get you the guys # I think he will ship. |
| Author: | dustertech2000 [ Thu Apr 01, 2010 6:29 pm ] |
hey thanks alot but i just found a posi unit for my 7 1/4, with brand new clutchs,ring/pinion,bearing,axle bearings. |
| Author: | Rick Covalt [ Sat Apr 03, 2010 5:04 am ] |
| Post subject: | Shims |
So it takes just one additional shim under each gear? And where do you buy the shims? I may need to try this. Rick |
| Author: | andyf [ Sun Apr 04, 2010 9:00 am ] |
Just weld it together to make a spool. Circle track guys have doing that since about 1930. |
| Author: | Doc [ Mon Apr 05, 2010 11:36 am ] |
| Post subject: | Re: Shims |
Quote: So it takes just one additional shim under each gear? And where do you buy the shims? I may need to try this.
I have a lot of side gear shims if you need a couple.Rick DD |
