| EFI manifold fab'n https://slantsix.org/forum/viewtopic.php?t=3964 |
| Author: | GTS225 [ Fri Jul 26, 2002 10:55 am ] |
| Post subject: | EFI manifold fab'n |
Well, I've started the mods/fabrication on an EFI intake, using an early Clifford piece. After being quoted $100-$120, by a couple shops, for machining the needed holes into the runners, I went into cheapskate mode and figured it out for myself. Had to fab-up a fixture that enabled me to do the job with a twenty-one dollar rotary file/burr and a drill press, (available at work), maintaining the proper 45* angle. IMO, it worked quite well. Yes, I'm taking pics as I go along in order to draft up a "chapter" for an ongoing article, from a nuts/bolts viewpoint. It's a little slow going for me, so please be patient. Oh, and if anybody's interested, the fixture is available for use, but it might get a touch pricey UPS'ing it to the ends of the country. Roger GTS225@aol.com |
