| Windshield Lockstrip Source '62-'66 A Bodies? https://slantsix.org/forum/viewtopic.php?t=39641 |
| Author: | Walter Lee Jackson [ Tue Mar 30, 2010 1:06 am ] |
| Post subject: | Windshield Lockstrip Source '62-'66 A Bodies? |
Is there a lockstrip available that duplicates/approximates the original? [And, no, the gm type with the rounded top that shows up all over ebay is not the one I'm looking for!] Would the Dodge Trucks for those years be a source? TIA --Walt Jackson |
| Author: | SlantSixDan [ Tue Mar 30, 2010 6:33 am ] |
| Post subject: | Re: Windshield Lockstrip Source '62-'66 A Bodies? |
Quote: Is there a lockstrip available that duplicates/approximates the original?
No. Quote: [And, no, the gm type with the rounded top that shows up all over ebay is not the one I'm looking for!]
Then...no.Quote: Would the Dodge Trucks for those years be a source?
No. |
| Author: | Walter Lee Jackson [ Tue Mar 30, 2010 11:01 am ] |
Thanks, Dan. I was afraid of that. GM it is, then. --Walt Jackson |
| Author: | dakight [ Tue Mar 30, 2010 8:40 pm ] |
Unless it's somehow different, the lockstrip canbe purchased out of Australia. http://www.pentastarparts.com.au/sunsho ... ail&p=1087 |
| Author: | SlantSixDan [ Tue Mar 30, 2010 9:15 pm ] |
The Australian lockstrip has a smooth/rounded contour, like the GM truck stuff. (the one you've linked to is black, not chrome. Echk, do not want.) |
| Author: | ev2slant6 [ Thu Apr 01, 2010 10:58 am ] |
You may want to check with a local auto glass shop. I've been able to locate some generic strip that way |
| Author: | walpolla [ Thu Apr 01, 2010 2:56 pm ] |
hello W L J, various widths of that lock strip are available in Australia. I take it that the profile that you want is important? if you can post a close-up pic of the profile,I will check my local supplier of such stuff,and see how we go. precise measurements will be helpful too. regards,Rod |
| Author: | Walter Lee Jackson [ Fri Apr 02, 2010 12:02 am ] |
>if you can post a close-up pic of the profile,I will check my local supplier of such stuff,and see how we go. precise measurements will be helpful too. < This is very generous of you. I don't have a digital camera, but will see what I can do. --Walt Jackson |
| Author: | walpolla [ Fri Apr 02, 2010 12:32 am ] |
measurement width wise and trace around the profile,pop it in your scanner,and post a copy of the scan here an option? W L J wrote: "This is very generous of you." ---- oh it will cost ya !! regards,Rod |
| Author: | walpolla [ Mon Apr 05, 2010 2:36 pm ] |
bump. Walt,I was only joking about costing you ! If you decided to buy something from over here,well that is a different story. I can check suppliers if you want. --- free ! regards,Rod |
| Author: | Walter Lee Jackson [ Mon Apr 05, 2010 4:38 pm ] |
Would it help if I sent you a sample of the strip? If yes, PM me with you address. Thanks, --Walt Jackson |
| Author: | walpolla [ Tue Apr 06, 2010 1:47 pm ] |
email sent. failed to deliver - fatal flaw in address it says. PM sent. regards,Rod |
