| parallel vs perpendicular https://slantsix.org/forum/viewtopic.php?t=39646 |
| Author: | hello, operator [ Tue Mar 30, 2010 6:34 am ] |
| Post subject: | parallel vs perpendicular |
when machining an intake, i have heard a few of you state that it is best to run a two barrel carb parallel rather than perpendicular to the motor. Why is that? isnt the stock 2 barrel intake have the carbs perpendicular? thanks, Lucas |
| Author: | valiant1966 [ Tue Mar 30, 2010 9:34 am ] |
I feel it's a matter of fuel distribution. In theory(I don't know if anyone has actually tested it) you have one barrel feeding 3 cylinders each. Just because the factory did it a particular way, doesn't make it right. They make a compromise between economics, driveability and performance. |
