| windage try help https://slantsix.org/forum/viewtopic.php?t=3966 |
| Author: | 69dart [ Fri Jul 26, 2002 4:46 pm ] |
| Post subject: | windage try help |
I just got the short block back from the machine shop and started to put on my windage tray. I used the ARP studs. The holes in tray had to be opened up to the 1/2" studs. The extra thick nuts ARP uses for these do not let the tray get any closer than 250-300 thou(eyeball). Mike (J&M) recomended 80-100 thou roughly. I hate to take the nuts off and am not sure what to use if I did. Has any one used these studs with the J&M windage tray and how did it work out? Thanks Steve |
| Author: | Doctor Dodge (Doug Dutra) [ Sat Jul 27, 2002 1:44 am ] |
| Post subject: | Re: windage try help |
: I just got the short block back from the : machine shop and started to put on my : windage tray. I used the ARP studs. The : holes in tray had to be opened up to the : 1/2" studs. The extra thick nuts ARP : uses for these do not let the tray get any : closer than 250-300 thou(eyeball). Mike : (J&M) recomended 80-100 thou roughly. I hate : to take the nuts off and am not sure what to : use if I did. Has any one used these studs : with the J&M windage tray and how did it : work out? : Thanks : Steve I have used these studs without much trouble but I was running a stroker crank. Sounds like you will need to face some material off the studs / nuts, or bend some dips into the tray's mounting rails. DD |
