It is currently Thu Nov 19, 2026 5:48 pm
PostPosted: Fri May 14, 2010 6:26 am
I'm running a 833 O/D and a 4.10 rear.
I seem to remember someone telling me it is the white gear?
Yea / nay?
Thanks!
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
-67 Dart /6 4bbl, Leaning Tower of Power!!!
PostPosted: Fri May 14, 2010 9:37 am
The correct gear also depends on your tire size. There are calculations on the Tire Upgrade page.
PostPosted: Fri May 14, 2010 11:17 am
Year One also has a gear sizeing chart listing tire size & rear end gear ratio as well as gear color located in the transmission section. If you need to get a different sized gear, search the net for a good buy as prices are all over the map on these devices.
PostPosted: Fri May 14, 2010 3:58 pm
6 Pack Dart
Check out
http://www.tciauto.com/Products/TechInf ... _gears.asp
Users browsing this forum: Bing [Bot] and 6 guests
