It is currently Sun Nov 15, 2026 9:38 pm
PostPosted: Fri Apr 02, 2010 6:20 pm
Does anyone know if there is a bellhousing to put a New Process 435 behind a 225? If so where can I get one? I've already looked around in the local salvage yards and can't find one. If I can't find(or there isn't) one I'm thinking about making an adapter.
Or does anyone have a better suggestion for a manual transmission to put behind a slantsix that is relatively short and can have a transfer case mounted behind it?
Thanks in advance
New = not always better.
PostPosted: Fri Apr 02, 2010 6:38 pm
yup they made a ton of trucks equipped that way.
PostPosted: Fri Apr 02, 2010 7:14 pm
do you know where I can find one? I have had some salvage yards tell me that was never a combination.
 Post subject: Lol...
PostPosted: Fri Apr 02, 2010 10:04 pm
I have two of those bellhousings...what year truck?
Where are you located?
FYI,
You will an 11" clutch and flywheel to use the bells...
