| New Process 435 Behind SL6? https://slantsix.org/forum/viewtopic.php?t=39687 |
| Author: | SVLSLIM [ Fri Apr 02, 2010 6:20 pm ] |
| Post subject: | New Process 435 Behind SL6? |
Does anyone know if there is a bellhousing to put a New Process 435 behind a 225? If so where can I get one? I've already looked around in the local salvage yards and can't find one. If I can't find(or there isn't) one I'm thinking about making an adapter. Or does anyone have a better suggestion for a manual transmission to put behind a slantsix that is relatively short and can have a transfer case mounted behind it? Thanks in advance |
| Author: | volaredon [ Fri Apr 02, 2010 6:38 pm ] |
yup they made a ton of trucks equipped that way. |
| Author: | SVLSLIM [ Fri Apr 02, 2010 7:14 pm ] |
do you know where I can find one? I have had some salvage yards tell me that was never a combination. |
| Author: | DusterIdiot [ Fri Apr 02, 2010 10:04 pm ] |
| Post subject: | Lol... |
I have two of those bellhousings...what year truck? Where are you located? FYI, You will an 11" clutch and flywheel to use the bells... |
