| Inaccurate gas gauge https://slantsix.org/forum/viewtopic.php?t=39694 |
| Author: | Reed [ Sat Apr 03, 2010 1:13 pm ] |
| Post subject: | Inaccurate gas gauge |
My 83 Dodge van has a 36 gallon gas tank. The other day i put 25 gallons in and the gas gauge reads full. However, I know I can fit another 11 gallons in the tank. The gauge travels smoothly down the rest of the gauge as gas is used. What causes this and is there any way I can correct the gauge to show "Full" only when the true full 36 gallons have been put into the tank? |
| Author: | Fopar [ Sat Apr 03, 2010 2:09 pm ] |
Put a longer arm on the sender unit and adjust or don't worry about it. |
| Author: | SlantSixDan [ Sat Apr 03, 2010 2:40 pm ] |
Possible sender/tank mismatch |
| Author: | Reed [ Sat Apr 03, 2010 3:11 pm ] |
Hmm. Okay. I am fairly certain it is all original, but I will run this tank dry and then check if the sending unit is original. Wait a minute. Ugh. On vans the sending unit is on top of the tank. So I have to pull the tank to check. I guess I just won't worry about it or I will cut a hole in the floor over the tank to get at the sender. |
| Author: | SlantSixDan [ Sat Apr 03, 2010 4:30 pm ] |
Confirmed: 22- and 36-gallon tanks use different senders per '82-'83 FPC. |
| Author: | dakight [ Sat Apr 03, 2010 5:50 pm ] |
If it's accurate in the lower part of the range I wouldn't worry about it. |
| Author: | Reed [ Sat Apr 03, 2010 7:18 pm ] |
Yeah, it just bugs me. But it seems like almost every car I have ever owned does this- it sits on F for a long time, and then works normally. Maybe I just overfill my tanks? |
| Author: | volaredon [ Sat Apr 03, 2010 7:24 pm ] |
| Post subject: | Re: Inaccurate gas gauge |
Quote: My 83 Dodge van has a 36 gallon gas tank. The other day i put 25 gallons in and the gas gauge reads full. However, I know I can fit another 11 gallons in the tank. The gauge travels smoothly down the rest of the gauge as gas is used. What causes this and is there any way I can correct the gauge to show "Full" only when the true full 36 gallons have been put into the tank? what? you mean you started with an empty tank when you put the 25 gallons in? had to be if you "know" that you have room for 11 more gallons. |
| Author: | Reed [ Sat Apr 03, 2010 8:12 pm ] |
Good point. I guess I need to drive it till it drops, then count from there. |
| Author: | 6shotvanner [ Sat Apr 03, 2010 8:35 pm ] |
My 83 with 36gal tank sorta works like that I guess.Top half goes down fairly quick,bottom half seems to move slower.Even at 1/4 it only takes 22-23 gals,I figure it's just a built in safety margin plus at 3 bucks+ a gal it would hurt more to be putting in another 30+ bucks.It's just a feel good game I play with mine |
| Author: | Reed [ Sat Apr 03, 2010 10:27 pm ] |
Quote: at 3 bucks+ a gal it would hurt more to be putting in another 30+ bucks.
Yeah, that's why I only pumped 25 gallons. Most gas pumps around where I live will only let you pump $75 worth of gas at one go. So to do a full fill up I need to put in $75, then restart the pump. Annoying.
