It is currently Mon Jun 01, 2026 12:16 pm
PostPosted: Thu Apr 08, 2010 12:19 am
Hi. Does anyone know where I can download a detailed one. The shop manual is a little unclear. My issue is my ebrake goes tight and the brakes work when I press on the pedal. However, the ebrake, which has all new cables and is tight and the shoes are adjusted properly, does not work. It looks like there is a bracket that goes between one of the shoes and the part in the brake mechanism that is moved by the cable. The cable pulls and is tight. It just doesn't spread the shoes. Like I said, the hydraulics are working fine and they do the trick. Anyway, I am looking for a diagram that will show me in detail if I'm missing anything. Thanks in advance. John.
'63 signet 200 owner
PostPosted: Thu Apr 08, 2010 6:15 am
Click for larger version:
