It is currently Sat Jul 18, 2026 2:34 am
 Post subject: my friends cuda
PostPosted: Sat Feb 08, 2003 11:53 am
my friend alos has a 65 and is putting a v8 into it he was wondering if there were any headers that would fit on a 82 318 that would work with a power steering pump, without having to cut stuff up and if he had to cuts stuff up then what type of headers should he get.
if it aint a chrysler it's just fish bait.
PostPosted: Sat Feb 08, 2003 1:41 pm
Choices are pretty limited for the early A. Spitfire comes to mind, but it's a crapshoot as to when you'll get them. However, he does make the only set that don't require cutting out the fenderwells. (I think) Post over on Moparts about Harold/Spitfire, someone will give you his phone number. :shock:
PostPosted: Mon Feb 10, 2003 1:10 pm
If you don't mind paying the coin, the old '68-'69 340 HIPO exhaust manifolds will fit with a little massaging where the coupling collar strikes the right side manifold. The sb magnum manifolds might fit, but you would have to try them on for fit.
Users browsing this forum: Amazon [Bot], Google [Bot] and 6 guests
