| Compression Ratio https://slantsix.org/forum/viewtopic.php?t=39772 |
| Author: | Shaker223 [ Fri Apr 09, 2010 4:56 pm ] |
| Post subject: | Compression Ratio |
My CR works out to 7.94:1 with the Wiseco pistons I had made. Head is 58.75 cc and the pistons sit down .1675" Perfect to boost up! |
| Author: | Dart270 [ Fri Apr 09, 2010 5:26 pm ] |
Yep, I'd say that's about perfect. What cam are you using? Lou |
| Author: | Greg Ondayko [ Sat Apr 10, 2010 5:50 am ] |
Tom, Did you get the Stretch Gauge to work or did you go with the TA gauge? Greg |
| Author: | Shaker223 [ Sat Apr 10, 2010 6:39 am ] |
I ended up adding a spring to the the stretch gauge so it can support its own weight. It looks like it should work fine now. I have not had a chance to work on the short block since Weds . |
| Author: | madmax/6 [ Sat Apr 10, 2010 6:36 pm ] |
I just torqued mine to what the card said,and went the 30 degrees????,,,,,,whatever the card said,further.Guzzi Mark |
| Author: | Shaker223 [ Sat Apr 10, 2010 6:41 pm ] |
Quote: I just torqued mine to what the card said,and went the 30 degrees????,,,,,,whatever the card said,further.Guzzi Mark
Thats my back up plan....but have this tool and would have to borrow the other.
