3:55 vs. 3:90 gears for my 198 with 4bbl, auto 3 spd. dual
https://slantsix.org/forum/viewtopic.php?t=39774
Page 1 of 1
Author:  Mr Scamp [ Fri Apr 09, 2010 6:14 pm ]
Post subject:  3:55 vs. 3:90 gears for my 198 with 4bbl, auto 3 spd. dual
Any opinions on highway driveability for 3:55 vs. 3:90, I like power, but also want to be able to drive a couple hours to shows. Will the 3:90 be too high revving along for highway. It seems I only hit about 4000 in my 198. Thanks for your help!
Author:  SV162 [ Fri Apr 09, 2010 6:19 pm ]
This will help you work what revs you'll be doing at what speed.
http://vexer.com/automotive-tools/speed-rpm-calculator
If it was me I'd go with the 3.55's
Author:  Joshie225 [ Fri Apr 09, 2010 7:12 pm ]
I don't even like 3.55s for freeway driving. I like 3.23s much better. It depends a lot on what you can stand for 2 hours.
Author:  wjajr [ Sat Apr 10, 2010 7:59 am ]
Mr Scamp,
I have 3.55 gears turning 14 inch tires in my 67 Dart. I find that 55 to 60 mph @ around 3000 rpm is a bit busy on a long haul. Where I don’t use my car for a daily driver I can put up with the annoyance motoring 100 miles or so one way to car shows on weekends. With this car’s Turbo Sonic mufflers singing loudly, I generally stuff my ears with those foam hearing protection plugs, making a much more enjoyable journey, particularly when the tachometer drops into the head rattling, resonating, 2500 rpm range.
2.23 gears would drop my 55 - 60 mph rpm about 300 revs. Where you want to be rpm wise at cruse depends on your cam and toque curve. For a stock engine, I should think 3.90 would be way too much gear.
Author:  robert west [ Thu Apr 15, 2010 9:38 am ]
for you rpm range I would go no more then 3.55.in mine I run 4.10 with a 27 tall tire and going down the highway I'm turning 4,000 + just to keep up with traffic.hope this helps you out
