It is currently Fri May 22, 2026 9:28 am
 Post subject: slant 6 dodge dart
PostPosted: Wed Mar 24, 2010 9:20 pm
by chance does anybody know how hard would it be to convert a columm to a floor shift ?
I have a 68 4dr Dart
 Post subject: Depends...
PostPosted: Wed Mar 24, 2010 9:47 pm
At least...
Floor Shifter
Shift rods
Linkage
Boot and Floor Bezel
Floor Hump
Gotta make sure the tranny has the bosses on the tailshaft for the floor shifter, if not...you'll be needing a tailshaft swap, another tranny, or a custom install...
I've done this on my '67 already swapping in a '74 floor shift 3 speed set up into a column shift Auto tranny A-body....
PostPosted: Thu Mar 25, 2010 8:18 am
If you are going thru all the work of converting a "3-on-the tree" manual, non-syncrow 3-speed, why not go to a 833 4-speed?
PostPosted: Mon Apr 12, 2010 6:33 pm
thanks for the info any pics ? sorry first time working with a classic . from what doner car can i get this parts ? also what about converting it to a auto. ? will a 70 dart parts work .
I have a doner car in sight that has the all the drivetrain in it.
 Post subject: Yep...
PostPosted: Mon Apr 12, 2010 6:47 pm
Floor shift hump is aftermarket or any 1967-1976 A-body (Dart/Valiant/Demon/Duster/Dart Sport-1967-1969 Barracuda)...
You can swap in an automatic easily if:
You use a tranny from a 1968+ car to match your engine crank hub.
You will need the streering column, shift linkage, tranny cooler lines,
and possibly the Radiator (Most radiators have the the auto tranny cooler bungs and the cooler...I have had a couple of "cores" from manual cars that had an air leak in that part of the tranny, but didn't leak antifreeze).
Make sure to get the flexplate off the crank as well, and mark the flaex plate and one bolt hole with some white paint, so you know how it goes back together.
PostPosted: Tue Apr 13, 2010 6:04 pm
what about the driveline same??? and any wiring issues i should look out for and thankyou p.s. does anybody have schematics on how to connect the vacuum lines on my carb it seems that i have two one that was mounted in it but it seems to leak right under the float bowl in the corner pin hole? but the other is a holly 1920 but has a couple of more connections
Users browsing this forum: Google [Bot] and 21 guests
