Fuse Box Infeed Wire Melting!
https://slantsix.org/forum/viewtopic.php?t=39848
Author:  jason [ Thu Apr 15, 2010 5:18 pm ]
Post subject:  Fuse Box Infeed Wire Melting!
I have been having problems with my gas gauge and temperature gauge not working. I have tried many things (including checking the board, changing voltage limiter etc...). Finally I looked at the back of my fuse box and noticed that the wire labelled "battery infeed" on the electrical diagrams is at least partially melted. Can anyone tell me why this is happening? I can change the wire, but I would like to solve the problem so I don't have to keep changing them!
Thanks
Jason
Author:  Fopar [ Thu Apr 15, 2010 6:21 pm ]
A high amp load, could be caused by a bad connection causing a higher amp to get the power through.
Author:  jason [ Thu Apr 15, 2010 8:39 pm ]
Any idea where to look for a bad connection? Could it be the voltage regulator?
Author:  Fopar [ Thu Apr 15, 2010 9:09 pm ]
Look after the infeed, like the fuse block (good clean terminals if you do not blow correct amp fuses) :!:
