Dampener for a cast crank/auto trans
https://slantsix.org/forum/viewtopic.php?t=39863
Page 1 of 1
Author:  ppsi [ Fri Apr 16, 2010 5:58 pm ]
Post subject:  Dampener for a cast crank/auto trans
I have looked a lot here about the dampener for my slant which turns out to be a 1978 block with a cast crank.The dampener is shot and I am forced from a $ standpoint to look at a few used dampeners but they are all pre cast crank units. From what I have come to understand these should be OK for an auto trans cast crank vehicle yes? I know it is not great using an old unit but the money needed for a new one is not available right now.
Thanks
Howard
Hampstead, NC
Author:  Doc [ Fri Apr 16, 2010 6:01 pm ]
I keep seeing new ones on ebag for under $50.00
Author:  ppsi [ Mon Apr 19, 2010 2:23 pm ]
I've looked on hebay for weeks and have not seen anything under vibration, dampener, vibration???
Author:  SlantSixDan [ Mon Apr 19, 2010 3:06 pm ]
Dampener means a device or system that applies water or some other liquid to wet (dampen) some other device or area.
Damper means a device or system that controls unwanted movement, noise, or vibration.
Keep watchin'; they do go across eBay with pretty good frequency.
Author:  emsvitil [ Mon Apr 19, 2010 4:02 pm ]
So the damp water pump was a dampener for the damper...............
Author:  powerwagonpaul [ Tue Apr 20, 2010 5:00 am ]
i too will need a dampner soon. will this work for my 71 with an auto?
http://cgi.ebay.com/ebaymotors/SLANT-6- ... 53e0d8f231
Author:  DusterIdiot [ Tue Apr 20, 2010 5:20 am ]
Post subject:  Yes and no...
The 6 spoke in that auction would be what PPSI is looking for (never seen one drilled for balance like that...). The 1971 needs a 3 spoke damper for the forged crank...they can interchange but the cast crank damper is lighter than the forged crank version by a smidge.
Author:  coconuteater64 [ Tue Apr 20, 2010 7:39 pm ]
I'm pretty sure any of the forged crank dampers would work, as long as the requisite number of pulleys is present. I bought one off feeBay and I think even with shipping it was under $50, new in the box.
